0 Members and 476 Guests are viewing this topic.
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
electricme
Quote from: Cap-Z-ro on June 19, 2011, 11:54:33 AM
In my experience, people who say things are impossible, are impossible to reason with.
Regards...
YES, a big AMEN to that, a closed mind that is not open to learning new things is about as useful as a door with rusty hinges. ;D
jim
Hey, I also am looking forward to the final day tommorra, what will be revealed?
AbbaRue
This device is like a Tesla coil, only it uses the earth's capacitance instead of the large electrode ball.
And it needs to be set into resonance like a Tesla Coil.
What better day to set up the resonance with the earth than on the longest day of the year.
Seeing Telluric currents travel from poles to equator during the day and the opposite way at night.
the_big_m_in_ok
Quote from: leo48 on June 20, 2011, 04:15:19 AM
;D
Tomorrow is the day of revelation ;D
Leo48
Could you be  more specific?
What revelation?
In reference to:  Who?What?When?Where?Why?
And is Leo48 your handle?
Here's my handle/signoff:
--Lee
FreeEnergyInfo
http://freeenergylt.narod2.ru/minimizator/
ХиÑ,рый выпрямиÑ,ель
Принципиальная сÑ...ема усÑ,ройсÑ,ва
   Ð¡Ñ...ема усÑ,ройсÑ,ва приведена на рис.1.
   ÐžÑÐ½Ð¾Ð²Ð½Ñ‹Ð¼Ð¸ элеменÑ,ами являюÑ,ся силовой выпрямиÑ,ель Br1, конденсаÑ,ор C1 и Ñ,ранзисÑ,орный ключ T1. КонденсаÑ,ор С1 заряжаеÑ,ся оÑ, выпрямиÑ,еля Br1 через ключ Т1 импульсами с часÑ,оÑ,ой 2 кÐ"ц. Напряжение на С1, а Ñ,акже на подключенной параллельно ему нагрузке близко к посÑ,оянному. Ð"ля ограничения импульсного Ñ,ока через Ñ,ранзисÑ,ор Т1 служиÑ, резисÑ,ор R6, включенный последоваÑ,ельно с выпрямиÑ,елем.
   ÐÐ° логическиÑ... элеменÑ,аÑ... DD1, DD2 собран задающий генераÑ,ор. Он Ñ,,ормируеÑ, импульсы часÑ,оÑ,ой 2 кÐ"ц амплиÑ,удой 5Ð'. ЧасÑ,оÑ,а сигнала на выÑ...оде генераÑ,ора и скважносÑ,ÑŒ импульсов определяюÑ,ся парамеÑ,рами времязадающиÑ... цепей С2-R7 и C3-R8. ЭÑ,и парамеÑ,ры могуÑ, подбираÑ,ься при насÑ,ройке для обеспечения наибольшей погрешносÑ,и учеÑ,а элекÑ,роэнергии. На Ñ,ранзисÑ,ораÑ... Т2 и Т3 посÑ,роен Ñ,,ормироваÑ,ель импульсов, предназначенный для управления мощным ключевым Ñ,ранзисÑ,ором Т1. ФормироваÑ,ель рассчиÑ,ан Ñ,аким образом, чÑ,обы Т1 в оÑ,крыÑ,ом сосÑ,оянии вÑ...одил в режим насыщения и за счеÑ, эÑ,ого на нем рассеивалась меньшая мощносÑ,ÑŒ. ЕсÑ,есÑ,венно, Т1 Ñ,акже должен полносÑ,ью закрываÑ,ься.
   Ð¢Ñ€Ð°Ð½ÑÑ,,ормаÑ,ор Tr1, выпрямиÑ,ель Br2 и следующие за ними элеменÑ,Ñ‹ предсÑ,авляюÑ, собой исÑ,очник пиÑ,ания низковольÑ,ной часÑ,и сÑ...емы. ЭÑ,оÑ, исÑ,очник обеспечиваеÑ, пиÑ,анием 36Ð' Ñ,,ормироваÑ,ель импульсов и 5Ð' для пиÑ,ания микросÑ...емы генераÑ,ора.
Ð"еÑ,али усÑ,ройсÑ,ва
МикросÑ...ема: DD1, DD2 - К155ЛА3.
Ð"иоды: Br1 â€" Ð"232А; Br2 - Ð"242Ð'; D1 â€" Ð"226Ð'.
СÑ,абилиÑ,рон: D2 â€" КС156А.
ТранзисÑ,оры: Т1 â€" КТ848А, Т2 â€" КТ815Ð', Т3 â€" КТ315. Т1 и Т2 усÑ,анавливаюÑ,ся на радиаÑ,оре площадью не менее 150 см2 . ТранзисÑ,оры усÑ,анавливаюÑ,ся на изолирующиÑ... прокладкаÑ....
КонденсаÑ,оры элекÑ,ролиÑ,ические: С1- 10 мкФ Ч 400Ð'; С4 - 1000 мкФ Ч 50Ð'; С5 - 1000 мкФ Ч 16Ð';
КонденсаÑ,оры высокочасÑ,оÑ,ные: С2, С3 â€" 0.1 мкФ.
РезисÑ,оры: R1, R2 â€" 27 кОм; R3 â€" 56 Ом; R4 â€" 3 кОм; R5 -22 кОм; R6 â€" 10 Ом; R7, R8 â€" 1.5 кОм; R9 â€" 560 Ом. РезисÑ,оры R3, R6 â€" проволочные мощносÑ,ью не менее 10 Ð'Ñ,, R9 - Ñ,ипа МЛТ-2, осÑ,альные резисÑ,оры â€" МЛТ-0.25.
ТрансÑ,,ормаÑ,ор Tr1 â€" любой маломощный 220/36 Ð'.
Наладка
При наладке сÑ...емы соблюдайÑ,е осÑ,орожносÑ,ÑŒ! ПомниÑ,е, чÑ,о низковольÑ,ная часÑ,ÑŒ сÑ...емы не имееÑ, гальванической развязки оÑ, элекÑ,рической сеÑ,и! Не рекомендуеÑ,ся в качесÑ,ве радиаÑ,ора для Ñ,ранзисÑ,оров использоваÑ,ÑŒ меÑ,аллический корпус усÑ,ройсÑ,ва. Применение плавкиÑ... предоÑ...раниÑ,елей â€" обязаÑ,ельно!
Ð'начале проверяюÑ, оÑ,дельно оÑ, сÑ...емы низковольÑ,ный блок пиÑ,ания. Он должен обеспечиваÑ,ÑŒ Ñ,ок не менее 2 А на выÑ...оде 36 Ð', а Ñ,акже 5 Ð' для пиÑ,ания маломощного генераÑ,ора.
ЗаÑ,ем налаживаюÑ, генераÑ,ор, оÑ,ключив силовую часÑ,ÑŒ сÑ...емы оÑ, элекÑ,росеÑ,и (для эÑ,ого можно временно оÑ,соединиÑ,ÑŒ резисÑ,ор R6). Ð"енераÑ,ор должен Ñ,,ормироваÑ,ÑŒ импульсы амплиÑ,удой 5 Ð' и часÑ,оÑ,ой около 2 кÐ"ц. СкважносÑ,ÑŒ импульсов приблизиÑ,ельно 1/1. При необÑ...одимосÑ,и для эÑ,ого подбираюÑ, конденсаÑ,оры С2, С3 или резисÑ,оры R7, R8.
ФормироваÑ,ель импульсов на Ñ,ранзисÑ,ораÑ... Т2 и Т3, если правильно собран, обычно наладки не Ñ,ребуеÑ,. Но желаÑ,ельно убедиÑ,ься, чÑ,о он способен обеспечиÑ,ÑŒ импульсный Ñ,ок базы Ñ,ранзисÑ,ора Т1 на уровне 1.5 â€" 2 А. Если Ñ,акое значение Ñ,ока не обеспечиÑ,ÑŒ, Ñ,ранзисÑ,ор Т1 не будеÑ, в оÑ,крыÑ,ом сосÑ,оянии вÑ...одиÑ,ÑŒ в режим насыщения и сгориÑ, за несколько секунд. Ð"ля проверки эÑ,ого режима можно при оÑ,ключенной силовой часÑ,и сÑ...емы и оÑ,ключенной базе Ñ,ранзисÑ,ора Т1, вмесÑ,о резисÑ,ора R1 включиÑ,ÑŒ шунÑ, сопроÑ,ивлением в несколько Ом. Импульсное напряжение на шунÑ,е при включенном генераÑ,оре регисÑ,рируюÑ, осциллограÑ,,ом и пересчиÑ,ываюÑ, на значение Ñ,ока. При необÑ...одимосÑ,и подбираюÑ, сопроÑ,ивления резисÑ,оров R2, R3 и R4.
Следующей сÑ,адией являеÑ,ся проверка силовой часÑ,и. Ð"ля эÑ,ого воссÑ,анавливаюÑ, все соединения в сÑ...еме. КонденсаÑ,ор С1 временно оÑ,ключаюÑ,, а в качесÑ,ве нагрузки используюÑ, поÑ,ребиÑ,ель малой мощносÑ,и, например лампу накаливания мощносÑ,ью до 100 Ð'Ñ,. При включении усÑ,ройсÑ,ва в элекÑ,рическую сеÑ,ÑŒ дейсÑ,вующее значение напряжения на нагрузке должно быÑ,ÑŒ на уровне 100 â€" 130 Ð'. Осциллограммы напряжения на нагрузке  и на резисÑ,оре R6 должны показаÑ,ÑŒ, чÑ,о пиÑ,ание еÑ' производиÑ,ся импульсами с часÑ,оÑ,ой, задаваемой генераÑ,ором.
Если всÑ' исправно, подключаюÑ, конденсаÑ,ор С1, Ñ,олько вначале емкосÑ,ÑŒ его принимаюÑ, в несколько раз меньше номинальной (например 0.1 мкФ). Ð"ейсÑ,вующее напряжение на нагрузке замеÑ,но возрасÑ,аеÑ, и при последующем увеличении емкосÑ,и С1 досÑ,игаеÑ, 310 Ð'. При эÑ,ом очень важно внимаÑ,ельно следиÑ,ÑŒ за Ñ,емпераÑ,урой Ñ,ранзисÑ,ора Т1. Если возникаеÑ, повышенный нагрев при использовании маломощной нагрузки, эÑ,о свидеÑ,ельсÑ,вуеÑ, о Ñ,ом, чÑ,о Т1 либо не вÑ...одиÑ, в режим насыщения в оÑ,крыÑ,ом сосÑ,оянии, либо полносÑ,ью не закрываеÑ,ся. Ð' эÑ,ом случае следуеÑ, вернуÑ,ься к насÑ,ройке Ñ,,ормироваÑ,еля импульсов. ЭксперименÑ,Ñ‹ показываюÑ,, чÑ,о при пиÑ,ании нагрузки мощносÑ,ью 100 Ð'Ñ, без конденсаÑ,ора С1, Ñ,ранзисÑ,ор Т1 в Ñ,ечение длиÑ,ельного времени не нагреваеÑ,ся даже без радиаÑ,ора.
Ð' заключении подключаеÑ,ся номинальная нагрузка и подбираеÑ,ся емкосÑ,ÑŒ С1 Ñ,акая, чÑ,обы обеспечиÑ,ÑŒ пиÑ,ание нагрузки посÑ,оянным напряжением 220 Ð'. ЕмкосÑ,ÑŒ С1 следуеÑ, подбираÑ,ÑŒ осÑ,орожно, начиная с малыÑ... значений, Ñ,ак как увеличение емкосÑ,и приводиÑ, к увеличению выÑ...одного напряжения (до 310 Ð', чÑ,о можеÑ, вывесÑ,и из сÑ,роя нагрузку), а Ñ,акже резко увеличиваеÑ, импульсный Ñ,ок через Ñ,ранзисÑ,ор Т1. Об амплиÑ,уде импульсов Ñ,ока через Т1 можно судиÑ,ÑŒ, подключив осциллограÑ,, параллельно резисÑ,ору R6. Импульсный Ñ,ок должен быÑ,ÑŒ не более допусÑ,имого для выбранного Ñ,ранзисÑ,ора (20 А  для КТ848А). Ð' случае необÑ...одимосÑ,и его ограничиваюÑ,, увеличивая сопроÑ,ивление R6, но лучше осÑ,ановиÑ,ься на меньшем значении емкосÑ,и С1.
При указанныÑ... деÑ,аляÑ... усÑ,ройсÑ,во рассчиÑ,ано на нагрузку 1 кÐ'Ñ,. Применяя другие элеменÑ,Ñ‹ силового выпрямиÑ,еля и Ñ,ранзисÑ,орный ключ сооÑ,веÑ,сÑ,вующей мощносÑ,и, можно пиÑ,аÑ,ÑŒ и более мощные поÑ,ребиÑ,ели.
Обращаем Ð'аше внимание на Ñ,о, чÑ,о при изменении нагрузки, напряжение на ней Ñ,акже будеÑ, сущесÑ,венно изменяÑ,ься. ПоэÑ,ому усÑ,ройсÑ,во целесообразно насÑ,роиÑ,ÑŒ и использоваÑ,ÑŒ посÑ,оянно с одним и Ñ,ем же поÑ,ребиÑ,елем. ЭÑ,оÑ, недосÑ,аÑ,ок в определенныÑ... случаяÑ... можеÑ, оказаÑ,ься досÑ,оинсÑ,вом. Например, изменяя емкосÑ,ÑŒ С1 можно в широкиÑ... пределаÑ... регулироваÑ,ÑŒ мощносÑ,ÑŒ нагреваÑ,ельныÑ... приборов.
