0 Members and 475 Guests are viewing this topic.
tagor
Quote from: dllabarre on July 02, 2011, 09:08:01 AM
In my opinion I believe the Kapagen converted MAINS (120v/60hz) into high voltage, high frequency electricity which can easily light many regular light bulbs.  I don't believe there was any OU, just a conversion of electricity from 1 type to another more efficient type for a specific purpose.
ok , but with JLN last data ( something like COP = 0.9 ) ... if you put
the kapagen in a calorimeter , you get the COP > 1
PS :
do you get your light bulbs hot or cold ?
ramset
bolt
Sending the funds today ! Looks like I have some work these next few weeks ,so I hope to
maintain this once a week for now!
To those of you that can't experiment with this Tech
bolt has offered to take a shot at it ,and open source his findings,If we help cover some costs!
I'll take bolts attempt any day over my own,and will gladly send him the scratch that I would have  wasted  experimenting with  this.
How Bout You??
bolts donation link
http://tinyurl.com/6xvesuk
Chet
Ps
An example of bolts Open Source HHO project
www.sites.google.com/site/silverfreeenergy/
PPS
bolt Thanks for this opportunity ,It feels good to Help ;D
Send A Buck to bolt...................
Thanks Grandma
bolt
Just the first tiny steps today i built my HV rig from flyback and now got variable pulse width and frequency for the fly-back from 10khz to 100khz. Quite interesting kicks you get off those wires and they jump about at 40kV at 25 watts.   Its too powerful for what i need but then i guess better to have a bit too much than too little i need to tame it a tad.  Also got too much Ozone.
Still waiting on stuff from China should be here in a week or two.
forest
Quote from: bolt on July 03, 2011, 03:45:35 PM
bolt
Btw, how did you measured output frequency from flyback ? Is that the same as input frequency and how I can be sure about that ?
bolt
To be honest i never checked the flyback o/p going near it with any test gear is fatal. If you are careful a loose scope lead some 12 inches away can easy take a sample of the o/p. I only measure the fet switching side. In any case frequency is not so critical for HV ferrite excitation but stability IS important so no Katchers or Joule Thiefs.
That said in not happy with this for final solution using a flyback is overkill a few kv is enough and also getting access to flyback will be hard soon as old monitors and tv's end up in landfill. Needs universal application for anyone to make even 4 part joule ringer proved a MAJOR problem world wide as not everyone sells Fujitsu flash camera with correct HV transformer so i need to make one designed around standard ferrite ring.
