FreeEnergyInfo
xenomorphlabs
Quote from: bolt on July 03, 2011, 11:20:28 PM
To be honest i never checked the flyback o/p going near it with any test gear is fatal. If you are careful a loose scope lead some 12 inches away can easy take a sample of the o/p. I only measure the fet switching side. In any case frequency is not so critical for HV ferrite excitation but stability IS important so no Katchers or Joule Thiefs.
That said in not happy with this for final solution using a flyback is overkill a few kv is enough and also getting access to flyback will be hard soon as old monitors and tv's end up in landfill. Needs universal application for anyone to make even 4 part joule ringer proved a MAJOR problem world wide as not everyone sells Fujitsu flash camera with correct HV transformer so i need to make one designed around standard ferrite ring.
@Bolt: Maybe a little 3-4 kV NST would be easier obtainable for most people around the world?
If your flyback circuit operates between 20-40 kHz, then it should be easy to replace it later with such NST.
electricme
Hello All,
This is a great forum and there is a lot of excellent information here.
But I could see there exists a situation, where are the details to put together "stuff".
So I have made a Kapanadze Topic here   http://www.overunity.com/index.php?topic=11105.new;topicseen#new
which is designed to Compliment this Kapanadze one here.
This is to allow people to talk about the "Devices" (successful or otherwise), they have made or want to make, and how they went about making them and the reasons to make them.
For example, I needed to make a 2000 volt power supply to supply power while my own Kapanadze is being made.
I wanted to be sure the "devices" I have made do actually work to eliminate the possibility "it/they" or a "part" were the cause of a failure.
Testing a series light string using the power supply.
Info on how to make a high voltage Analog Volt Meter to keep an eye on the MOT's 2Kv output.
No doubt there will be other good ideas we could try.
So please hop along and take a look see and join in.
jim
dencyaupin
Information from Vladimir Pantyukhova http://letitbit.net/download/38923.3a05232f979e4ae641c7fefbe029/Ð'ладимир_ПанÑ,ÑŽÑ...ов_200_ваÑ,_самозапиÑ,ка.rar.html
