0 Members and 1699 Guests are viewing this topic.
justasm
Here is the translation from http://www.youtube.com/watch?v=uxQ99R4gOWY video.
Please note that I try to translate as they say, but also important info is that Russian language is not their native language, so their Russian translated into English might need some additional thinking.
Here is the legend for talking people:
TK - Tariel Kapaladze
BG - Big guy with white shirt
VwF - Voice without face
BS - guy with black shirt
hmhmh - unrecognized speech
0:13 [BG] - hmhmh this is good ground
0:17 [BG] - The earth (ground) entered the device, and now we will be ... (jump)
0:22 [TK] - This is primary coil hmhmh,
0:28 [TK] - Secondary coil
0:31 [TK] - Well here is the main thing that is in Tesla also.
0:36 [TK] - this is not very strong coil but we placed it here in such way that it would under electro magnetic field of primary coil.
hmhmh
0:50 [VwF] - And this on big black? This is cooler?
0:53 [TK] - yes this is cooler. for hmhmh second (???? this is very unclear)
0:57 [VwF] - this is (pointing to bulbs) 200W each.
0:59 [BG then TK] - This is one kW
1:01 [TK] - we need this temporary
1:18 [TK] - We replaced it, we had it electric, but it died.
1:29 [TK] - It would be now checked the strength of electro magnetic field and maybe we will have to check the radiation also, because hmhmh.
Then goes series of Georgian language
2:05 [BS] - here, here you can easy stand here and there is no problems (keeping the hand on water pipe).
2:11 [TK] - To hold it in hands is better.
2:16 [VwF] - Ok, let me hold it.
2:48 [VwF] - ... and there is no radiation at all.
3:03 [TK] - we haven't tested it yet, haven't test it, but it will be long working device. We haven't tested how long it will work continuesly.
3:12 [TK] - Because of that I offered one thing: lets create 2 devices, one working then automatically it would be switched to second one. That means that you will get current because user cannot suffer and we will be able to inspect the first one whats, why and how.
END
Regards,
Justas
justasm
Here is some more info that I found in some Russian forums about Tesla car, that was powered by some mystical Tesla box with antennas :) This is nothing more, than the same Tesla transformator.
I tried to translate as close to the original text as I could, but some meanings (especially about aether)  was hard to understand myself, so I translated it like word to word. Hope it helps.
Tesla box which were, by the words of Tesla himself, consisted of Tesla transformer with three coils: one external primary, reeled up by very thick wire and two internal. Probably that characteristic winding of Tesla coils, some people also have mistaken to antenna as Tesla coils during operation were heated very much, so it is quite possible that Tesla has placed them outside of the car so that they would be cooled by a wind stream. Here and all history about the antenna. Lamps in a box of Tesla it only the to help to produce very short impulse with which help Tesla pumped up an energy to the primary coil of the transformer, moving apart an aether as water in a bath. The short impulse submitted on the primary coil of Tesla transformer, that is winded up from very thick wire moved apart an aether, creating impulses (??) radiant energy which was transferred to the secondary coil and simultaneously moved apart an aether. After the impulse removal, the compressing aether delivered much bigger quantity of energy to the secondary coils, than has been used. First secondary coil with the rectifier was powering the lamp circuit that was supplying impulses, witch, by the way also had the power stabilizer (regulator), because Tesla was afraid, that his device might blow away from excessive energy. To this acceleration pedal was and connected. From the second secondary coil the electrical energy was taken to power the engine it self.
Regards,
Justas
Cap-Z-ro
In Stefan's freeze frame capture the object circled in pink may be simplt a toggle switch.
And in the first video from Justas, the big box with the coil reminds me of a huge microwave magnetron.
Regards...
hartiberlin
Hi ALL,
I googled his name and found this directory full
of great circuit digrams and PDF files:
http://www.hvlabs.hu/zpe/Gruz/
Super !
hartiberlin
