0 Members and 457 Guests are viewing this topic.
xenomorphlabs
Quote from: energia9 on October 15, 2011, 02:19:59 PM
Are we Sure The Capacitor bank contains 6800 nanofarad 3kv caps?  is it not 6.8 nanofarad?? or 6800 picofarad?
It's more pikofarad. The "n" you might have seen is the cyrillic letter "п".
On the left side of the schematic it is written with a latin "p".
energia9
Quote from: xenomorphlabs on October 15, 2011, 02:37:34 PM
thanx xeno
wattsup
energia9
i do not think 25 kv is strictly a requirement, i think lower voltage caps will do it, they will have to do it because they store energy just like other, it can withstand 25 kv
T-1000
We posted most basic circuit for people to get replications successfully done over entire world. Adding complexity for perfomance is only after you fully understand on what each element in circuit does and when it proves in practice already.
For those who started replicating our setup and have difficculty with coils:
We used 1 meter x5 2mm diameter wire (makes multistrand wire) for caduceus coil and 5 meters of 2mm diameter for each secondary coil. So the mass of each secondary coil = mass of primary coil. The caduceus coil is winded from the middle of 1 meter multistrand wire (so 50 + 50 cm). Winding goes on 2 opposite wire ends intersecting each other on each 180 degrees.
Start winding secondaries on top of insullated caduceus coil from the middle of the tube with left hand windind on one and right hand winding on second, wind both at once. After you get coil done, get HF ferrite rod from old radio receiver, put it inside of tube int he middle. After correct tunning it should start heating up, so where ferrite heats up, you need insullation between pieces of ferrite.
Good luck!
P.S> For lower output it can be done with air coil in beginning - this is what you should get in electrostatic resonance. Also putting paper on spark path from secondary coil end will not burn paper - the discharge just goes through it. This is a sign of cold electicity you need. You can even touch it and won't get hurt (just avoid doing that on flyback HV wires!!!) The flyback transformer core is grounded for better efficiency, can work without ground too.
