0 Members and 311 Guests are viewing this topic.
Magluvin
If I may ask.
The caduceus coil.  Does anyone have any info as to what makes it special?
Is it that it has low self induction due to none of the windings being next to each other(other than the crossings)?  Is it the secondary ?
Mags
romerouk
@stivep
I understand the primary but not sure about the 2 secondary.
Can you confirm the pictures below or please clarify.
Regards,
Romero
stivep
The proper material is being prepared right now possibly in three dimensional format. Maybe tomorrow if we speed up.. Additional information are being discussed as we speak. If proper tuning is applied than the same elements
may give you range of few KW.
The first and primary is to understand self resonance of flyback.
I'm doing laboratory  measurements to explain how to do it without the lab.
Material  will be  posted in  traditional to me form as chunk of information but  in addition to that it will be discussed here.  I can not  do everything in one time .. video editing .. I'm not so  good in it.. I'm much better in lab and scientific investigation ...
Please understand..
Wesley
Flyback in my particular example was using 48Khz of self resonant frequency
Do not  cant on it!!!!!!!!!!!!!
All you have to do is get to the highest possible frequency  with the highes voltage present on  secondary of Flyback
but do not over do it...
This is the hint
Although Arunas   T-1000 suggested that  RAMP SHAPE  is the best ... I did not see difference between square or triangle in regards to sinus at self resonance..
Yes he is right  RAMP  gives you sharp cut out.. that is what we need ...
you may see without oscilloscope many resonance points  but that would be only harmonics...
The catalog resonance frequency for flyback I have is around 17KHz
But if you apply voltage to 100% of length of primary winding...
Depends which wind you use self resonance will be different at the same very  Flyback..
The biggest amplitude
I have got on square with 50% duty cycle.
remember this thing  can kill so be extra careful
hint: give try of 1V only (from signal generator) and you can measure HV on secondary..!!!!!!!!! with your V meter ... make sure that your V meter works  no not less than  100KHz..!!! If not it  may lie to you..
Pick the highest point and you should be at  resonance point.
No matter what have you give to primary you get sinus at secondary  at resonance..Make sure that amplitude is the same...
NO RINGING !!!!!!!!!!!!!!!!!!!!
xenomorphlabs
Quote from: Magluvin on October 18, 2011, 09:09:30 PM
If I may ask.
Mags
You could get a dozen different answers to that question.
Whenever someone tells you an answer, ask for the source ;)
Since most info about the matter comes from non-scientists,
one is as good as the other.
So it all comes down to "believing". 98% of all the info is not sourced
or backed by experiments.
As far as i know there is no
scientific textbook literature on the matter and lots of google-hits
delude you with new age ufo non-sense, anti-gravity, time-travel BS, weather manipulation up to hellraiser effects with devils jumping out of the wall (luckily it ain't that simple) :D
Often you find a crude statement that a caduceus coil has no magnetic field at all.
That might convincingly be true for the segments of the coil where the 2 wires
are apart from each other in a different winding sense.
The interesting area are the crossings.
I tend to "believe" one explanation going like:
QuoteOn the top and
bottom where the crossovers are, the fields overlap forming on the
top magnetic vectors orientated in one direction parallel to the
coil axis, and on the bottom vectors of the same magnitude oriented
oppositely to those on top. If we observe the coil from the side we
then see that the consecutive vectors along the coil axis would form
several closed toroidal loops circulating into the ferrite core.
Not to forget the fact that those coils are said to produce scalar "waves" (even though the term is contradictory)
Naudin has actually done some nice documented benchwork on that one.
I am planning to do some iron filing field tests with one, to verify
for myself what is really going on. Without that, you can't be absolutely sure.
Hope that helps you.
dllabarre
Quote from: romerouk on October 18, 2011, 09:09:30 PM
@stivep
Regards,
Romero
This is quote from T-1000 on a previous page on 10/15/2011:
Secondary:
"5 meters of 2mm diameter for each secondary coil. So the mass of each secondary coil = mass of primary coil.
Start winding secondary’s on top of insulated caduceus coil from the middle of the tube with left hand winding on one and right hand winding on second, wind both at once. After you get coil done, get HF ferrite rod from old radio receiver, put it inside of tube int he middle. After correct tuning it should start heating up, so where ferrite heats up, you need insulation between pieces of ferrite."
"left hand winding on one and right hand winding on second"
Does this mean CCW for first half and CW for second half, joined together in the middle?
DonL
