0 Members and 18 Guests are viewing this topic.
energia9
experimenting with plasma globes.. Donald smith also mentioned it and no wonder why... we understand him now.
T-1000
Hello everyone! :)
Please see more detailed circuit attached.
Few hints:
1) flyback must be in resonance with not fully saturatеd core.
2) The AV plug must work from "hot" wire after flyback transformer before connecting "cold" wire to secondary TT coil.
3) The HV sparks after secondaryt TT coil do not burn and do not hurt when coil is not connected.
4) The ferrite inside of TT magnifies effect and you must use tune variable capacitor before TT for it.
Have fun and good luck replicating it!
P.S> this forum does not show pdf, here it is - http://www.energeticforum.com/162929-post1235.html
xenomorphlabs
@T-1000 : Any chance of adding values to the schematic too for completeness?
Thank you and good work.
TEKTRON
Quote from: AbbaRue on October 19, 2011, 11:27:19 AM
What is wrong with TK?
If he is suffering from any form of infection then he is better at home.
Tell him to get some "calcium hypochlorite"  and put it into Gel Caps. from health store.
Take a "calcium hypochlorite" capsule with water every 2 to 3 hours.
In a few days he should be well again.
"calcium hypochlorite" is sold in swiming pool supply stores for very cheap.
It's called swiming pool shock, or swiming pool chlorine.
Just make sure he reads the ingredients, should say "calcium hypochlorite" 65% or something simular.
Here is a link to learn more about "calcium hypochlorite"  check link that says "Protocol 4000.
   http://jimhumble.biz/
REMEMBER it must say "calcium hypochlorite" on the package.
I get mine at Canadian Tire Store in pool section for $5 a bag of 0.4 kg. Very Cheap!
A couple of weeks ago I had strep throat really bad, took this and in 2 days it was gone.
This stuff heals many cancers too, everyone should know about this.
Anyone over 65 should take 1 capsule every day or so: to keep in good health.
Take this and you will have no more Colds or Flues, It even cures Diabetics.
Remember distilled water should be drank, and at least 2 cups with each capsule.
Very Important!  This could save TK's Life.
NO NO NO!!!! Calcium Hypochlorite is very strong bleach!!!!
You'd KILL him !!!! GET YOUR CHEMICALS RIGHT. STOP practicing medicine!!!
MMS is CHLORITE. BIG BIG BIG DIFFERENCE
Mannix
Quote from: Shokac on October 19, 2011, 05:03:35 AM
Effect of ´electron- or ion-cascade´ is known by special arrangement of conductors, like used e.g. at Testatika. Picture EV AEG 12 shows construction in principle.
Sheets of capacitor are winded spiral. One sheet takes negative charge (red), on surface takes positive charge (blue), between both sheets isolating material is installed (here not drawn). Several of such units are arranged one by one, where each inner end of sheet is connected with outer beginning of next corresponding sheet (here marked by thick black lines).
When discharging that capacitor-cascade, more ´electrons´ exit than originally put into system and ´ionisation´ is detected. Both effects however are only side-appearances, process by itself exclusively is based on pressure of Free Ether onto charges resp. overlaying motion ahead of current. Above this, no normal capacitor (-dipoles) nor isolation are necessary. Much more effect will show naked surfaces or wires (here thus only minus-sheets) which are exposed to Free Ether directly.
Ether is moving by light speed (at its local limited areas) and electric current can also move (approximately) by light speed (apparently ahead). Nevertheless, differences of lengths alongside spiral bended surfaces are important. Layer of charge show basic pattern of motions onto which is impressed overlaying motion-ahead (and synchronously also cross to), both by certain speeds.
At inner side of spiral, distances become shorter and space becomes more narrow, i.e. ether there comes into ´stress-situations´. Resulting of is thicker layer of charges at inner parts of surfaces. Free Ether affects stronger pressure into these thicker balancing areas, i.e. also with accelerating effect. Relative to length of conductor thus current will flow (apparently ahead) faster and faster towards inside of spiral. Alongside bended sheet-surfaces, charge layer will ´slip´ ahead increasingly faster. At round wire-surfaces, motions wind around-ahead correspondingly faster.
At picture EV AEG 13 schematic is drawn such an ´acceleration-cascade´, where conductive wire (red) is winded spiral and its negative charge resp. current runs through three of these truncated cones one by one (A, B and C). At the end of that unit, not ´more electrons´ appear, but charge there is impressed by overlaying motion much stronger and faster into direction ahead.
Within such coil-cones for example is piling up accelerated ´bow-wave´ with corresponding inertia into direction-ahead, however also with corresponding ´suction-effect´ into backward direction. Previous mentioned ´pump-effect´ thus is generated by this conception, now however only by direct affecting pressure of Free Ether onto charge-layer.
So it´s important, Free Ether can affect most free onto charge layers, i.e. these coils should be winded loose. Such units could be build by large scale or several of these coil-cones could be installed within small box, like e.g. sketched at this picture at D by view top-down (four coil-cones at different levels are arranged within box of not-conductive material). This current now should be allowed to ´fall into depression´.
Just a side note on this ... perhaps this is the vital detail that we/I  missed in the hendershot coil's layered internal cap?
@T1000
Thanks for the circuit . ... self run version   wow!
Some triodes for the drivers ?   Later
