0 Members and 463 Guests are viewing this topic.
dllabarre
Quote from: stivep on October 24, 2011, 08:39:47 PM
not good!!!
Microwave diodes are good for 50Hz.
do not waste your money for it.
I have spoken with them  no spec  no information no tech support, when you buy over the phone you pay aprox 20% more.
They have  only few of  the diodes you need and do not promise  date of delivery
Wesley
If this device requires some very hard to get components then it isn't going to work for the general public.
DonL
energia9
Quote from: dllabarre on October 25, 2011, 07:24:24 AM
DonL
exactly....
Waves
I don`t believe that in Teslatime was very different diodes.
stivep
Quote from: Jury1 on October 25, 2011, 04:41:58 AM
@ Wesley
The black wire coiled is  probe improvised oscilloscope…
Recently, my hobby is «open systems». Often have unexpected situations - equipment failure.
My family budget does not allow each month to buy a new oscilloscope.
Therefore, I made the oscilloscope of the computer sound card. I use a program " Scope".
Scheme of the experiment -
http://xmages.net/storage/10/1/0/7/0/upload/2b7f1e43.jpg
I use the n-p-n bipolar transistor - 2SC3461.
Frequency of oscillation - 15,6 kHz.
Internal resistance  of multi meter  not affect to work of the transistor.
Important detail is the secondary coil of the transformer
She has resistance - 340 Ohm.
The questions still reminding unanswered from  my previous post:
Can you show closer waveform ( shape of waveform)
What is pick to pick voltage of oscillation?
What is multi meter -  type ( model number)?
What is range of DC V switch  to?
New questions:
Exactly how you made the coil.
- material,  for the former ( karkas, tam jest ferrit ili niet. Toczno czto i kak.)
- diameter
-primary    # of winds and wire diameter
-secondary # of winds and wire diameter
Jury you might be  on something but  it is important to get  as much info as possible.
As far as now? I do not understand why it works. It should not work  as an oscillator at all :)
Spasibo
Wesley
wattsup
Quote from: stivep on October 25, 2011, 08:02:05 AM
New questions:
- diameter
Spasibo
Wesley
@stivep
The question is if the multi-meter is removed from the series connection will the scope still produce the oscillation. I think the MM is providing enough power to jump the transistor internal diode.
wattsup
