0 Members and 50 Guests are viewing this topic.
John M
Did anyone try using a Ferrite ring from a magnet mount antenna base?
Also could someone for people like me give a quick run down on a replication that has been done and just how many on this group has been don?
T-1000
Quote from: Jdo300 on November 04, 2011, 12:18:31 PM
Also, if the input signal for the 51-turn coil needs to be synchronized with the resonant frequency, one can use something called an Injection-locked Oscillator circuit.
These oscillator circuits are used to lock the oscillator to the frequency and phase of the coil's resonance.
One thing I am not clear about is if the ~380 kHz resonance represents the bulk LC resonance of the 51-turn coil itself (with the given core) or if this is specifically related to the some kind of nuclear resonance of the core material itself. *If* this is the 51-turn coil's natural resonant frequency with the particular core, it can easily be found by simply injecting a single pulse into the 15-turn coil and looking at the response (frequency of oscillation) of the 51-turn coil. I was thinking about this as I'm sure many people don't have access to a spectrum or impedance analyzer.
@Wesley & Arunas,
Can you comment on if the above method would be a valid alternative to identify the 51-turn coil's resonance?
Thank you,
Jason O
Injection-locked Oscillator produces sine wave, isn't? We work with square wave on higher frequency. So additional logical circuit needs to be there.
~380Hkz is lowest harmonics with highest amplitude for resonant point and we try to keep with lowest frequencies as possible due skin effect and EM radiation after. The natural resonant frequency is 1,66Mhz in our case - http://freeenergylt.narod2.ru/aidas/1_spectr_analiz_ferit.jpg
Quote from: grizli on November 04, 2011, 12:30:25 PM
What about this simple circuit ?
WHAT determines frequency here ? Because this circuit is SELF tuned !!
http://www.powerlabs.org/images/schematic1.gif
Maybe this can work directly with our core hmm
Blocking generators are good but not enough for resonant output of seciondary coil with SINE WAVE. They keep own frequency, but it is hard for them to work stable on needed resonant frequency or its harmonics. But we still use feedback for conventional generators so it keep sync on own frequency.
romerouk
grizli
Quote from: T-1000 on November 04, 2011, 01:24:27 PM
Sync,sync , sync :D
So tell me for correct operation do we NEED circuit that tune frequency to keep resonance automaticly .
Does circuit works without 50 hz signal ? can we rise that 50 hz signal to 100 hz or 1000 Hz , what will happened ?
Again what kind of feedback do you sue for "sync" ,and how do you define "sync", If you use CONSTANT frequency manually tuned signal generator, then WHY do you talk about "sync"
Please can anyone explain in more details STIVEP, T-1000  ??
Why then not using PLL (there is PLL Tesl coil SS schematics) circuit that WILL tune frequency automaticly so that OUTPUT voltage is at maximum !!!
Will circit that detects Maximum voltage at output load coil work here ?
STIVEP SAID:
7. tune that generator to maximum voltage on bifilar output.( OSCILLOSCOPE AT OUTPUT + hv probe)
TESLA PLL circuit will do this automaticly!!!
grizli
