0 Members and 257 Guests are viewing this topic.
grizli
grizli
Quote from: itsu on November 06, 2011, 08:20:18 AM
Baroutologos
I don't think the Primary A 50 Hz 15 turns coil is driven into resonance.
My 15 turns has an inductance of 120 uF and a natural resonance frequency of 1.550 Mhz (1550 Khz).
The calculated capacitance of the turns is then 87 pF.
To get this coil resonating on 50 Hz would mean to add 85 mF (= milli Farad) of capacitance.
Another indication that this Primary A 50 Hz coil is not being driven in resonance is the fact that
T-1000 states in reply #8349 that it is been driven by a Sinus Wave.
Perhaps T-1000 can confirm this.
Another observation i make is that the resonance of the ferrite when measuring the 2 copper plates/strips/braid
is 5.785 Mhz in my case, so not in the 1 - 2 Mhz range mentioned.
I measured this with my scope and FG, the scope both in scope mode as well as in FTT (spectrum) mode.
Could be that my yoke from a recent computer monitor has different spec's, but when looking to the "spagep kontur.jpg"
scope shot in reply #8043 (page 537) i see a nice (resonance?) sine wave of 7.58Mhz when appearently driven by a
FG frequency of 1.660 Mhz (ramp wave).
To me this means that also here the ferrite resonance frequency is in the 5-7 Mhz range.
Just my 2 cents.
Regards Itsu
TRY putting more TURNS to 50 turn coil, make 100 turns and measure frequency , it should drop from 7 Mhz below !!
Smaller cores require more turns
verpies
Quote from: Rafa12 on November 06, 2011, 07:14:48 PM
No, but I 'm not sure maybe just this notch have to be isolated... I think it has not to be isolated, and the diamagentic material, (paper in the video) will create a isolation between two half.
This is bad because the Braid will be in the air gap, widening it too much.
From your answer it looks like the Braid will make electric contact with one half of the ferrite, where the air-gap is supposed to be. Even the slightest contact takes away the sense of the tape insulation between the Braid and ferrite elsewhere.
It is bad for the braid to make electric contact with either half of the ferrite, since the ferrite is slightly conductive and it destroys the capacitive effect of two insulated surfaces (a shorted transmission line in this case).
Finaly, this is definitely not how the inventors had routed the Braid.
Rafa12
oh yes! I am really wrong, I will replace the braid by cooper sheet trying to cover all yoke surface. Thank you verpies!
aether22
I am starting a build, but questions pop up...
I am able to get solid core 18AWG wire that is enamel coated.
I am able to buy suitable plastic coated multi-strand hookup wire that should have a similar current carrying capacity.(but is not rated with a wire gauge that I can see)
However I have not yet found where to buy solid core wire with a plastic coating which is what I assume is used?
Should I still try anyway with either multi-strand or solid enamel coated wire?
Question 2, what is the winding direction on the 2 primary coils? (unless it has been tried both ways and makes no difference)
And with the output coil, Do you wind the 2 wire together or in opposite directions like a caduceus coil? (that would explain why it doesn't feed-back into the primary and kill the gen.)
Question 3, So if I want about 150w output I don't have the braid connected to anything? And no flyback is used?
Question 4, The braid does not pass between the core halves but a wire connects the inner and outer I assume? (or is the Braid in one piece?)
Question 5, I think there is much confusion and miscommunication about the 2 imputs along with plenty of unknowns so this question is perhaps the most important and is in 2 pieces:
5a: I have this function generator: http://www.amazon.com/Function-Generator-RSR-MHz-Sweep/dp/B0007ZGXCC/ref=pd_sbs_hi_3  and I will need to source another for the 50hz, for arguments sake let's say I buy another (just to keep it simple) would you expect that by directly connecting the output of each gen to their respective 50 and 15 turn coils I would be able to replicate the effect without any modification to the function generators or addition of any other circuitry?
5b: Please explain everything that has been used successfully to power the high and low frequency primaries, including any required (or awfully unseful) circuitry and the brand & model of the function gen. and details of the generated the waveforms. It looks like in the video 2 function generators are used, great if I wanted to buy them where would I go?
Question 6: So am I correct in summing the device as so:
A normal function generator is directly connected to a 50 turn coil and inputs a high frequency 50% duty cycle pulsed DC at over 300khz, nothing else is connected to this circuit.
A second normal function generator (operating independently of the first) is directly connected to a 15 turn coil, this is set to about 50hz sine wave.
These coils are wound of solid 18AWG (or is it 18SWG?) solid core plastic coated wire. <I am most unsure about this point
There is a shield/braid/plate etc that can be made of various materials that was added so that it would work without needing body capacitance. <This is a guess
This is not electrically connected to anything unless you want to ramp up the power with the optional flyback option. (that will destroy the ferrite in time)
The braid/shield is in 2 pieces an inner and outer connected at one end to each other by a wire.
The bifilar coil is wound together and connected so that the magnetic field generated by the 2 windings is in agreement as is the voltage induced, this is connected to a single halogen 150w bulb only. (although adding capacitors across the bulb may be desirable but not required, and capacitors can likely be added to all 3 coils)
The only point left to mention is that so far only one type of Russian made yoke has been used successfully and it has a 90 degree angle. (I hope this is not so and other different CRT yokes have proven successful!)
And that the primary half of the Yoke is wrapped in electrical tape and there is paper separating the 2 halves.
I want to thank the 3-4 of you very much for your commitment to humanity, please help me and others looking to build this by giving the information so that we can build in confidence and verify your results!
Thanks in advance!
