0 Members and 73 Guests are viewing this topic.
aether22
Quote from: escalator on November 07, 2011, 10:19:30 AM
Hi:
After reading again the last 20 pages of the thread I see that some people are asking how to sync the generators without any clear answer given. The Velleman generators used on the video have no sync input so I cant see a way to do it with those generators. All the screen captures shown are related to these generator models that work as standalone without sync capabilities. Someone can explain this?
My best shot at an explanation is that the device in the video has no sync (and given the huge disparity of frequencies none should be needed) but that when some asked if sync was a good idea or needed T-1000 thought it was and said yes.
But if that is so then does that mean T-1000 didn't use it but wants us to try so he doesn't have to (to see if it is worthwhile) or does it mean that he didn't actually build it (the vid is from another) and he is just guessing? (or a third option which I don't believe where it is a fake that he perhaps believes could be made too work buy having people try it)
BTW, I would guess that possibly the position of the bulb (over the yoke) might effect it's output.
This is just a theory based on my understanding of aether vortex fields also called torsion that suck in EM.
verpies
Quote from: grizli on November 07, 2011, 02:51:45 PM
If we scope copper sheet coil alone: why we need to add capacitor to sheet coil in operation ?
BRF <> FRF
e.g.: 1.6MHz <> 382kHz
I already discussed this here:
Quote from: verpies on November 06, 2011, 06:19:25 AM
This winding (a shorted transmission line actually) will apparently resonate by itself.
I would expect that the Braid winding stimulated with a transient sharp rectangular pulse, would ring with a 1.6Mhz sinewave on the falling edge of that rectangular pulse, without any capacitors in parallel
I like to call this ringing frequency - the Ferrite Resonant Frequency (FRF) although it is apparently the resonance of  a shorted transmission line with a complex ferrimagnetic medium (with multitude of unconventional effects).
The capacitors in parallel with that Braid winding are there apparently to lower the FRF of 1.6MHz to the Braid Resonant Frequency (BRF) of 382kHz, making the BRF the 4th subharmonic of FRF.
( FRF / BRF = 4 )
Apparently resonating the Braid winding at the full FRF is impractical for some reasons.
Hope
Quote from: bugler on November 07, 2011, 03:46:21 AM
Can any one post the information to replicate the device.
This thread is so long that I have no idea where the essential information can be.
Thanks.
All interested in build please start reading from page 500 for recent schematic diagrams and revisions.
Hope
Quote from: Collapsingfield on November 07, 2011, 05:17:54 AM
@T1000
Thanks for the new detailed info. I don't understand how can you give 50Hz to 15 turn winding by the mentioned generator. At 50Hz its impedance is much lower than 50 Ohm, the USB based generator will not able to supply it with power. Another question is that there is no input on the USB generator, where are connected the mentioned 1 turn feedbacks? Thank You for your efforts again.
The PCGU1000 FG and the PCSU1000 Multi-Function O Scope ARE USB based BUT they have there OWN power supplies drawing from the AC outlet.  They are NOT drawing power from your computer.
grizli
Quote from: verpies on November 07, 2011, 03:15:01 PM
BRF <> FRF
Ferroresonance freq = copper sheet coil resonance with capacitor  !!
In other words we have to tune copper sheet coil capacitor so that what coil natural LC resonates to ferroresonance frequency, whish is higher harmonic to 380 khz, and equals 1,6 mhz (somerthing like that)
hmm
if we pulse copper sheet coil it will LC resonate , but if we pulse 50 turn coil it will make ferroresonance by higher harmonic of 380 khz (just guess value)
that ferroresonance I think has nothing to do with LC value of copper sheet coil
but we want to make LC copper sheet coil resonance to be equal as ferroresonance that is driven by higher harmonic of input 380 khz signal..
