0 Members and 73 Guests are viewing this topic.
Hope
Quote from: Mannix on November 07, 2011, 06:50:21 AM
I think that when we eventually get it working properly it must act as an amplifer to the input signal 50 hz .
On that video showing a yoke core coil powered by a 1.5 volt battery he got the output to 450 volts when he tapped it with a stack of small bar neos magnets.  This perhaps suggests we are doing the same with our FG's.
The most interesting effect was that it stayed ringing at that voltage without any other components or inputs other that the one cell (D cell) staying attached.   I believe it was Wattsup's video.  He tapped it at the area between the windings and had an equal stack of magnets attached 180 degrees from where he tapped.  (Tapped = touched briefly)
Hope
Quote from: energia9 on November 07, 2011, 08:02:17 AM
i have experimented, things are happening the exact way aidas, arunas, wesley say, no theories will make your device work!  DO IT and you will know!!!
everything has to be adjusted piece by piece, you will not suceed with a fixed thing....
trust it, the phenomenon is not explained in conventional science, and media will still try to supress it although it can be reached by anyone this time.
All physics books needs either adding more info or completely rewriting... :o
Excellant news, please post all data you can to include photos, schematics, equipment used,  all P ins and P outs, waveforms at Pin/Pout's .  Do you have any precision 1 ohm resistors you can measure across?  Do you have any wattmeters or amp meters.  You can build a high voltage probe,  look at instructables.com for DIY instructions.  You can get a mega ohm resistor heavy enough from an old broken tv (the picture tube will work as a fantastic HV capacitor BE CAREFUL).  The bleed off resistor for the CRT (picture tube) at the ground straps area will work for a DIY HV probe, be SURE to incase it in materials that will protect you from getting ZAPPED!
Still awaiting my PCSU1000.
verpies
@grizli
In Wesley's device - what do you think is the resonance frequency of the Transverse Coil (the 1turn copper plate coil) without an additional capacitor in parallel?  1.6MHz or 382kHz ?
I think it is more appropriate to treat the Transverse Coil as a Transmission Line shorted at one end.  It has its own capacitance (L) and inductance (L) but I bet its natural resonance frequency is not equal to a lumped LC circuit's 1/(LC)^0.5.
A conventional 125 meter long transmission line shorted at one and (without additional capacitors at the input) will resonate at 1.6Mhz.
In the Wesley's device Transmission Line is ~1000x shorter but it has very unusual medium as its core, with 3 simultaneous perpendicular E&H field vectors.
Rafa12
Beautiful cores guys,
I am still trying to find a good configuration for this part (in blue). Anybody has build it correctly? Tiger, do you have a picture showing this detail.
all the best,
Mannix
Congratulations!!! You must be in a very different frame of mind .  When you cool down a little there are  2 things I want to ask  to join you sooner rather that a bit later .
Your sync circuit ?(just a rough description)
The ferro res cap?
