0 Members and 73 Guests are viewing this topic.
grizli
Quote from: verpies on November 07, 2011, 05:13:12 PM
@grizli
In Wesley's device - what do you think is the resonance frequency of the Transverse Coil (the 1turn copper plate coil) without an additional capacitor in parallel?  1.6MHz or 382kHz ?
I think it is more appropriate to treat the Transverse Coil as a Transmission Line shorted at one end.  It has its own capacitance (L) and inductance (L) but I bet its natural resonance frequency is not equal to a lumped LC circuit's 1/(LC)^0.5.
A conventional 125 meter long transmission line shorted at one and (without additional capacitors at the input) will resonate at 1.6Mhz.
In the Wesley's device Transmission Line is ~1000x shorter but it has very unusual medium as its core, with 3 simultaneous perpendicular E&H field vectors.
in Wesley device there is NO circuit RESONANCE when he measures using network analyser,  there is just ferroresonce, natural 90 degree coil resonance is  at much much higher frequency, remember its just single turn , So we need to add cap that natural LC 90 degree coilresonance equals ferroresonance (whish is property of ferrous material)
QuoteI think it is more appropriate to treat the Transverse Coil as a Transmission Line shorted at one end.  It has its own capacitance (L) and inductance (L) but I bet its natural resonance frequency is not equal to a lumped LC circuit's 1/(LC)^0.5
it does not matter, just I am sure that natural 90 degree coil without added cap resonates at much higher frequency,..  adding cap makes it resonate at lower
if we would network spectrum analyse whoe spectrum there could be another peak that equals fnatural Lc resonance
http://freeenergylt.narod2.ru/aidas/1_spectr_analiz_ferit.jpg
See hoe ferroresonace is SHARP, such sharpness has nothing to do with second order LC,
forest
@grizli
Good progress sir !  ;D  I think as soon as you eliminate copper braid from the picture you will see it is antenna.
forest
Controlling magnetic flux field by radio waves at 90 degrees. Efficiently at peak of sinewave wave."Nothing is SOMETHING" ;D
grizli
Quote from: forest on November 07, 2011, 05:41:31 PM
there where is ferroresonance in whole story ?
cosmoLV
How i understand and see stevep and others push peoples far away back from real principle of the device! Very clever and you are still believe....
Why you not take for real what Tariel say? why nobody see at linde's device which Tariel shows at end of green box video? why nobody look at electricity as water and gas?
where are engineering - Kindergarten!!! Return to earth and think with your own head...!!!
I'm Disappointed
________
Keep your chakras opened :)
