0 Members and 73 Guests are viewing this topic.
starcruiser
for the oscillators there are a few options and they were mentioned prior, one of them is to use 555 timers and construct a simple triggered one shot, use the sense coil to trigger it. Use a high pass and a low filter network to filter the frequencies and use the resultant signals to trigger your one shots. Or purchase the required signal generators with a facility for external trigger/sync. still may need the filters I mentioned depending.
I like the 555 timers since they can be run on a 9vdc battery.
Other options would be blocking oscillators and the like, these could be entrained by sense coils in proximity to the main torrid and should operate in their required frequency range. Use a simple small torrid for the blocking osc and this can also be used to entrain them to sync.
Regards,
Carl
Osiakosia
Good day for all ,
I have a luck to find whole TV unit "Rubin" .
Here is few photos . When measurement equipment
will arrive in my workhouse I will try to make replika
of this OU device . If you need measurement of the ferite
please let me to know .
“Nothing is impossible, except that the state of your mind makes it so"   Prof. John R.R. Searl
Shokac
This is my research over the past month or two and doing quite well. Enough current to fall after the merger of HV that the device will be able to propel himself. The next step is to make a loop.
