0 Members and 67 Guests are viewing this topic.
verpies
Quote from: grizli on November 09, 2011, 08:30:54 AM
Method #2
Apparently the effect is reciprocal and can be measured either by method #1 or method #2.
It would be an interesting experiment to compare if both measurement methods yield the same frequencies.
grizli
Quote from: verpies on November 09, 2011, 03:11:09 PM
If it is a multi-plate air capacitor then it will be limited to approximately 3000 Volts.
This is assuming that the distance between the plates is 1mm.
Air breakdown (sparking) will occur above 3kV/mm and corona discharges will begin even below this breakdown voltage. See:
http://en.wikipedia.org/wiki/Peek%27s_law
This is most likely why one of the inventors suggested removing every other plate of the air capacitor in order to increase the distance between the remaining plates.
Re: pt.2)
The paper in the "paper gap" must be impregnated with oranometallic compounds of the element 115 or it will not undergo permeability modulation and hence will not produce pseudoscalar waves which are essential for the operation of the device ;)
i justm ade some experiments and 50 hz is TOTALLY USELESS
its short circuit for such coil ,,.
and it is impossible to get waveform on the output coil like they got...
verpies
Quote from: grizli on November 09, 2011, 05:16:58 PM
I just made some experiments and 50Hz is TOTALLY USELESS
Yes, it would seem impossible with the 15turn coil alone, because at 50Hz this coil has such a low impedance that it appears as a short circuit to the weak signal generator.
However, if the 382kHz frequency somehow changes the rules of the game, e.g. by significantly increasing the effective permeability of the ferrite through some exotic effect, then this changes the big picture.
In this expanded picture, the 15turn coil stops appearing as a low inductance and low impedance load (short circuit) for the signal generator, and the HF 382kHz oscillation starts riding on top of the LF 50Hz oscillation.
See:
http://www.jjgifford.com/expressions/geometry/wave_addition.html
http://freeenergylt.narod2.ru/aidas/2_pirmine_iskociojimas_pjuklas__50_hercu.jpg
So your observation about the apparently devastating short circuit at 50Hz, might turn out to be good news after all, as it shows us a contradiction that we can sink out teeth in.
The very existence of this contradiction/impossibility explains the inventor's emphasis on the tuning of the LF by +/- few Hertz, that always seemed enigmatic and unnecessary to me.
See the inventor's quote below:
Quote from: freeenergylt.narod2.ru/aidas
9.
Tune  +/- few Hertz on it and see where this frequency starts carrying frequency from coil of 51 turns .
The above instruction is unusual because in normally summed waveforms, the HF will ride on top of LF always without any difficulty and the success of this waveform addition is independent of their frequency ratio and phase difference.
BTW: Because of the language barrier, the inventors wrongly call the effect of Waveform Addition as "carrying", instead of "riding on top".
This wrongly suggests that the LF is some kind of a "carrier wave".
See:
http://en.wikipedia.org/wiki/Carrier_wave
The impossibility that you had just pointed out might provide a key to understanding the tuning of the whole contraption.
NickZ
  Guys:
  Is it right to assume that a yoke coil from a 34 inch crt Tv would be something useful for this purpose, or not?  As my Tv has burnt and shorted the wires on this big ferrite yoke coil, and I have it removed it from the Tv and is available for this use.
   I realize that it is not the same as the ones shown and used, but since I have it, I would like to use it, if possible. Any advice is welcome.
        NickZ
