0 Members and 120 Guests are viewing this topic.
MasterPlaster
Quote from: verpies on November 14, 2011, 12:05:45 PM
Aidas, Arunas, Antanas, Tiger, Rostislav, Stivep
as listed on http://freeenergylt.narod2.ru/aidas/
Why doesn'nt some one here get creative. How about STAAAR?
MasterPlaster
Quote from: Jdo300 on November 14, 2011, 12:05:05 PM
At first, it sounds ridiculous that one could actually harmonically couple two frequencies with a ratio of 32000 difference, however, looking at the following post seems to show that that there are specific harmonics which show a particularly strong energy signature:
http://www.energeticforum.com/renewable-energy/5762-missing-fundamental-generator.html#post96365
Ironically enough, according to the harmonic charts shown in the post, harmonic 8,640 and 34,560 show huge magnitude peaks :).
Please watch this.
http://www.youtube.com/watch?v=jVATlX4XKMk
verpies
jbignes5
Quote from: T-1000 on November 14, 2011, 10:03:52 AM
We reinvented the wheel :) Like all other inventors around the world. The all credits go to Nicola Tesla!
And of course, the genuine approach of mixing longitudinal waves with common magnetic waves is half work. The second half is nuclear polarization in ferrite core... :)
Well I don't believe anyone can claim rights over this process. This is the very wheel work of the universe itself. I was merely pointing out that someone else had the idea. Lets concentrate on the task at hand to learn everything about this process. This is the very essence of the way things work. Be safe. Tesla made warnings about low level versions of this field. The lower the frequency the stronger the radiations become and eventually will affect your matter as well. Keeping the frequency above 2k is what he recommended. Yes you have to compensate by using higher voltages but the damage to matter becomes less and the response becomes higher because the density of the surface you create becomes higher but affects matter less this way.
There was a certain Iron Tesla used for this process. A very soft iron laminated very finely. This process was given to Westing House in trade for a prototype engine he designed. The steady state motor is genius in design and could supply us with all the power we need on demand, including vehicles because of the nature of the device being steady state.
If you have not figured out a circular piece of Ferris material can be charged. This is evident by the forces present that holds two halves together while working, Ed Leedskalnin figured this out. Once the circle is charged it has plenty of fluid inside of it. Sqeeeze it and it acts like a balloon the clowns make. You know the long thin ones. Think of a loop of that and squeeze a little portion and the entire tube expands. Even beyond the channel it rides in(Ferris channel). Think about this from that point of view and you will see what you are doing. Remember the surface longitudinal waves the copper is producing (both inside and outside of the core). What happens inside of the core imparts a small inertia to this surface. You could think of it like the event horizon of a black hole. There seems to be three different types of surfaces. All related to one charge polarity (+). One with all Big (+, low density, highest mass) magnetic field. One with Big (+, low density) and small (+, highest density) and one small (+, highest density) High Voltage field.
With the advent of the Bifilar coil this allows you to harvest both waves at the same time. Both north and south are harvested by the Bifilar and even double the force in one single direction, all in one package in one slice of time.
I hope this helps some.
P.S. Link about Health aspects of this energized field.  http://www.teslauniverse.com/nikola-tesla-article-high-frequency-oscillators-for-electro-therapeutic-and-other-purposes?start=20
verpies
Quote from: Haan on November 14, 2011, 06:47:21 PM
Where can "Tiger's schematic diagram" be found?.
Ask Ganzha, he posted this schematic. Apparently he is in communication with Tiger.
Quote from: Ganzha on November 12, 2011, 08:50:26 AM
I have attached a schematics of this device which Tiger send me yesterday.
