0 Members and 71 Guests are viewing this topic.
itsu
Severall answers:
@ verpies
1 Ohm measurements of my FG's: http://www.youtube.com/watch?v=CJQt1mD7bIc
100 Khz / 50% duty
Philips  Sine   5.4  V
         Square 8.8  V
China    Sine   2    V
         Square 1.92 V
@ All
caution about using a transformer as 50 Hz input as they will burn out.
Use a light bulb / resistor in series to protect the transformer:
http://www.youtube.com/watch?v=Izyg4TAh8jQ
Replication attempt of Aidas 100 Watt RF output phenomenon (unsuccessful):
http://www.youtube.com/watch?v=SXOUd9N5R3g
@ Wattsup
Minimum effect on 150 Khz,  but some 105 V PP output on 276 Khz, so
i see similar (less) results, but on an other frequency (not surprisingly):
http://www.youtube.com/watch?v=dO-6l6ifWwo
Regards Itsu
semenihin-77
verpies
@itsu
I think your signal generators are of decent quality and they do not introduce severe spectral artifacts even when driving low impedance loads.
I was surprised that the Chinese SG had less sine and square wave distortion across 1ohm load than the Phillips SG.
There is still a question how your signal generators react when they are forced to sink current, e.g. when an inductor discharges some previously stored electrical energy into them.
Other than that, your sinewave sweeps of the various windings should yield worthy data.
Also, I think that the light bulb in series with the ~50Hz 9VAC transformer and 15t winding is an excellent idea !
If this light bulb dims on that 15t winding at ~50Hz as you are varying other parameters of the system, it will be the first sign that something unusual is happening. So keep it there while doing all the future tests.
Also it's better to use light bulbs with a straight filament rather than a coiled filament in order to avoid introducing unwanted inductances into the system.
Increasing the output voltage of the above ~50Hz transformer will not hurt either.
However, if you want to have the ability to vary the LF ~50Hz frequency a little (just like Aidas recommends to harmonize with the HF oscillator), then you can drive the 15t winding from an analog automotive audio amplifier driven by your weaker sine wave signal generator.  Those car amplifiers are dirt cheap and designed to drive low impedance speakers.
This car amplifier trick will not work for the HF though (but a video output amplifier would).
I am too overwhelmed with data at the moment to comment on your spectrograms in detail. So before I can analyze them, I am just sticking to observations that I am very sure about.
One of them is that Wattsup's & Aidas' magic frequencies should not work in your device.  You have measured different frequency peaks in your experiments....
P.S.
Could you add static captions at the bottom of your future videos that state where each of the 4 windings is connected? e.g.:
t1 - NC, t50 -> Ch1, t15<-50Hz 9VAC, t150->50ohm
etc...
Not that I need these captions in your videos (your English is 100% clear to me), but I am sure that there are other viewers that understand only 5% of what you are saying.
However most importantly, I would like you to set an example to the STAAAR team how to properly document their tuning procedures.
bolt
Quote from: verpies on November 20, 2011, 07:58:26 AM
...and for non-rectangular waveforms this must be a high-power linear analog amplifier.
The simple Half-Brifge two transistor circuit does not work as a linear analog amplifier !!!
It is a double Class B amplifier that's good only for rectangular waveforms.
For non-rectangular waveforms a Class-A or Class-AB amplifier is needed.  Linearizing the H-Bridge is such a chore that it's better and cheaper to buy a premade amplifier.
There are many Video Output Amplifier or Line Driver integrated circuits that perform this function well from DC to 100s of MHz at power levels up to 25W.
The STK392 video deflection amplifier that the STAAAR team has been looking into at maxes out at 1MHz.
There are faster and more powerful Video Output Amplifiers and Line Driver ICs out there, ready to be used (made by e.g.: Sony, Phillips, MSK, AnalogDevices, etc...)
I agree with you BUT IMO having access to strong square drive is good enough.  When its in tune the o/p becomes sine in any case. Alike Rotoverter 3 phase motor 5 Horse Power can be driven and it will run at 3000 rpm using just 1.5 Watts Half H fet inverter!!
  Wesley videos show  its not required to go triangle or sine but i see too many people trying to use standard 1v PP 600 ohm sig gens then wonder why nothing is happening.  Those PC driven sig gens are expensive and could easy o/p 20 watts.  I suggest a simple Half H driver can be used to boast drive the coils from PLL for a total board cost under 10 bucks.  Also PLL can later to be used to provide lock sync control for max power o/p from the ferrite. You can not do this with most  sig gens unless they have phase control i/p loop.
itsu
@ verpies,
thanks for the comments, they are much appreciated.
I will look into those audio/video amplifiers.
Presently waiting on some variable capacitors which makes tuning easier.
I will keep in mind what you are saying about subtitles  :-)
Regards Itsu
