0 Members and 265 Guests are viewing this topic.
Cap-Z-ro
scianto
Quote from: bolt on November 19, 2011, 08:21:54 PMBasically anyone that has bought or using a standard sig gen MUST use some kind of an amplifier like this to pump at least 10 watts into the coils.   [/b]  The blurb from the website about this topology says: "  The main difference of the half-bridge converter is that it utilizes two large bulk capacitors (C1 and C2). These capacitors are connected so that each one is in series with one of the transistors. This means that power can be transferred to the output during the on-time for each transistor, which increases efficiencies to the 90% range. Since center-tapped transformers are not used, the problem with flux unbalance is also eliminated. These advantages also allow this type of converter to be utilized in power supplies up to 1000 Watts."
When you build it according to the posted schematic .jpg file, you may notice that the efficiency of the inverter is 50% to 75% at frequencies from ~45 to 200 Hz, and then you will wonder, why.
The reason is, as it comes from my experience, too high combined impedance (mainly resistance) of the two FETs and C1, C2. When the resistance of the primary winding of the transformer is low, for example 0,1 ohm, it's quite difficult to make this inverter more than 75% efficient. You need to chose most low resistance Cs and FETs so that as little as possible power is lost in them.
baroutologos
Quote from: Ganzha on November 20, 2011, 10:50:34 PM
Absolutely! We need Compass Tiger has it!
I have to say that in USSR there were a Magic Yoki, Magic inventors and even Magic People. It is pity that West World had destroyed all of that. I am not sure that now we could find "Magic" Yoki and Magic Ferrite from USSR! Sorry!
Istead of starting talking about magic here, can Tiger speaks for himself?
ps: the photo is not a yoke. its ferrite rings stacked in series ala SR example.
itsu
@ All,
New attempt to replicate with advice received from T-1000.
Max. output 188V, but voltage only.
Problem still is the amount of 50Hz voltage to be put into the 15 turn coil
in combination with the lack of solid ferrite resonance point.
Video with subtitles as proposed by user verpies :-)  :  http://www.youtube.com/watch?v=iA5s_3JxAvc
Regards Itsu
grizli
is it SO HARD to modify images , and write Russian to  ENGLISH translations directly in image?
