0 Members and 64 Guests are viewing this topic.
hartiberlin
Thanks for the translation Pirate.
Here is the orginal AVI movie.
It is 371 MBytes big:
http://www.hvlabs.hu/zpe/Gruz/free-energy.geo.avi
Now with all these new circuit diagrams it should be easy to replicate this circuit.
Regards, Stefan.
Groundloop
All,
Is there anybody that can translate the text inside box 11?
Groundloop
Pirate88179
This is my crude translation of the second PDF posted by Stefan:
We reflect on the patent Of [tariela] To [kapanadze].
Patent, as all other, is written by more juridical language, than technical. In the essence, it is the juridical document, intended in order to spoil the blood to competitors and to hold in control the development of technology, another purpose this form has property I I do not see. It is possible to certainly say that the inventor must be [voznagrazhden], but this reward frequently comes in this distorted form, that the inventor dies in the misery or steps from 14 floors… Whom is necessary this reward?
But in any event, under the crust of pettifoggery must be buried the essence of invention, in order to then present rights. [Pokopaemsya] to the essence.
Figure 1
Pirate88179
Figure 1 represents the diagram of the existing invention. The parts, connected with the invention are numbered and explained:
1- Power switch
is 2nd capacitor
3- points (as the distributor of engine)
4- high-frequency generator
it is 5th the first filter
6- Primary coil
7- first frequency regulator
is eighth second filter
9 frequency regulator (regulator)
10 second coil
11- second frequency regulator
12- output (phase) (positive) 12a- positive cable
13- output (neutral)
of 13[a]- negative cable
14- neutral particle (grounding)
15- initial electric power supply
A the cable of the first chain
C - the cable of the second chain
(Note from Bill:  For some reason, I can't copy the diagram from the PDF that goes with this but it appears very similar to the diagram Stefan posted from the patent, which is in English already.  Edit**  Here is a screen shot instead, thanks Jeanna)
Pirate88179
THE INDEPENDENT DEVICE OF ENERGY
the existing invention - device is self-sufficient ([samopitayushcheesya]) and is generating ready to use electrical energy, is neglected in the work with the initial electrical energy, obtained from the storage battery or a similar energy source, transferring the magnetic field, produced in the first coil to the second coil through the frequency regulator, after the rhythmical stabilization of the magnetic field of that appearing between the coils; it converts the independent energy - obtained the second coil from air - into the electrical energy.
Here like everything is understandable, in essence… Questions a total of several:
1.[Kak] to transfer magnetic field from the first coil to the second, through the frequency regulator? Frequency regulator this that?
2. Rhythmical stabilization of magnetic field, this as?
Existing invention
The existing invention derives external energy only in the first starting phase. This mentioned energy can be easily produced from the small storage battery or the battery or similar sources. After the device will be neglected after 1-2 seconds, switch at the entrance of device disconnects the external electrical
nourishment (from the storage battery or a similar energy source), producing electrical energy.
What does occur in these two seconds?
The very small part of this electrical produced energy they are used by a device in order to feed itself, and its large part is freed for the use. Thus far device is not switched off, or what problem did not occur inside, device produces energy constantly. There is no contemporary device whatever, similar to the existing invention, which generates energy constantly, and feeding itself.
I.e., for the work of device is required CONSIDERABLY less energy how it is obtained at the output. Consequently, device works as gate, for a certain natural process, the existing and elapsing independent of device itself.
The first chain is developed in order to produce electricity, transferring the magnetic field, produced in the first coil from the electrical energy, obtained from the independent initial electric power supply, to the second coil.
The first chain consists of the relay of time, capacitor, points, high-frequency generator, first filter, first coil, first frequency regulator (this chain it is shown by line in the figure),
thus, on
Thus, on the assertion of the author, precisely, this chain manufactures electricity, transferring the magnetic field of the first coil to the second. Magnetic field here… well how this to say [pomyagche]? Me seems - noodles, which to us they heap to the ears. Possibly, this terminology is used in order not to appear by white crow. Allegedly, all of the within the framework conventional idea about the induction. Let us isolate this chain separately.
