Ganzha
Quote from: Osiakosia on November 25, 2011, 03:44:39 AM
Hi Ganzha ,
Here is the link for one of the company's from San kt Petersburg .
http://www.azimut-ferrit.ru/serdechnikislozhnoyk/
I have checked all types ALREADY! There are no old types/////... unfortunately! But try!
Tiger:"[24.11.2011 11:08:10] tiger2007: ПривеÑ, Ð'адим . ЭÑ,а шÑ,ука Ñ,олько с эÑ,им Ñ,,ерриÑ,ом . Ð'оÑ, есÑ,ÑŒ в ниÑ... чÑ,о Ñ,о необычное ......
[24.11.2011 11:08:51] tiger2007: если ленÑ,у замкнуÑ,ÑŒ сильно грееÑ,ся , а лампа не гориÑ, ."
Hope
I have done a lot of CRT degaussing and the degaussing coil must be moved NOT the item being degaussed.  In this way you can turn the DG coil 90 degrees to item being degaussed and pull it away quickly AND shut if off (which also collapses field in a beneficial way).
AND that graph of inductance/reluctance sure looks a lot like the info from coil tuning from Tesla's nonograph chart and especially Don Smiths spin theories as stated in the Secrets of Telsa pdf recently linked here.
Why of all that has evidence shown about sparking (major white noise causing resonance in any/all domains) would we instead choose to excite the coils then use a waveform with NEGATIVE aspects.  Perhaps only to show how to use mains power to excite the cross X coil? (notice it is crossing each other at  90 degrees so that it does NOT cancel the oscillations)
We have so much so close it is inspiring to me and I feel you all are also excited.   Keep up your fine efforts.
edited for complete thoughts, LOL
wings
Quote from: Ganzha on November 25, 2011, 03:07:39 AM
This drawing had been made not him  -  but for him, in conversation and in Russian forum he explains me that he never user feerite rings such as H2000 and he considered that this type of ferrite is wrong to approve what I am talking about I could attached screanshots - if it would need!
My name is Ehrlich - it means Truth!
H2000
http://www.azimut-ferrit.ru/elektromagnitniepara/
TEKTRON
Ehrlich, The way I read it, He was following someone else's work and ended up NOT using (smashed up with a sledge hammer),yokes.
Or am I not reading this correctly?
http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fwww.001-lab.com%2F001lab%2Findex.php%3Ftopic%3D1056.20
tiger2007, here's a quote;
  Cardboard tube outer diameter of 50mm, vnutrinnyaya - 40mm between ferrite broken by TVS television and sedges.  foil on the outside, inside the foil.  Length of 140 mm.  winding on one side of the pump turns 50 vnaval wire 2mm, it served 50 Hz pulses 12c. Coil pickup - the same wire coils 20 on the other half, her lamp 12c 10vatt.  spark on foil internal to external useless when the light is sincere in full heat, power consumption drops by a quarter.  Good luck to all is simple.
  That's right, this is the experiment?
read this too:
http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.001-lab.com%2F001lab%2Findex.php%3Ftopic%3D455.msg14909%23msg14909&act=url
