0 Members and 67 Guests are viewing this topic.
verpies
Quote from: Ganzha on November 25, 2011, 04:01:54 AM
[24.11.2011 11:08:51] tiger2007: если ленÑ,у замкнуÑ,ÑŒ сильно грееÑ,ся , а лампа не гориÑ, ."
Translation:
"If the tape (strips) are closed (connected) then it heats up a lot and the lamp does not shine"
I have no idea what the pronoun "it" refers to. e.g. the ferrite,  the strips...?
I guess Tiger is not for connecting the copper strips together on the Yoke device.
From another schematic I gathered that instead Tiger prefers to connect the strips with a spark gap in parallel.
This way high voltage from the TV Flyback transformer builds up between the separated copper strips (acting as a capacitor) and above certain threshold the spark gap discharges that voltage, creating a pulse with a sharp falling edge of high slew rate (dV/dt).
The schematics of the Yoke device from the SAAAR team show the copper strips connected and a spark gap in series with them and a HV TV Flyback transformer.
In this arrangement,  the spark gap discharge  creates a pulse with a sharp rising edge of high slew rate (dV/dt).
Additionally the shorted strips constitute a 1turn Transverse Winding, through which electric current can flow during the discharge of the spark gap.
This current flow creates a transverse H-Field which would be absent if the copper strips were not connected.
They call this variation the "high power mode"
Alternatively the SAAAR team uses a capacitor in parallel with the connected coppers strips without a spark gap and the HV TV Flyback transformer input. Apparently stay mutual inductance from other windings induces current in the connected copper strips.  They call this variation the "low power mode"
Ganzha
Quote from: Ganzha on November 25, 2011, 12:17:17 AM
I am afraid that Yoke from USSR is quite different and includes Magic component unknown in West country's. Tiges said me that it works only in Yoke from old USSR TV sets and never from Japan or Korean OR Chines TV or Computer monitors. It is a pity news.
In first successfully device from Tiger (cylindrical coil)  he used a dust from Yoke cached between two tubes
Tiger2007 today conversation with me:
[15:28:51] vadim.ganzha: слушай помоги посÑ,авиÑ,ÑŒ Ñ,очку в споре - Ñ,уÑ, гуляеÑ, сÑ...ема по Ñ,ебе сделанная - на ней нари сованны Ñ,,ерриÑ,овая колбаса из колец Н2000
[15:29:47] vadim.ganzha: подÑ,верди - Ñ,Ñ‹ же не делал Ñ,акую колбасу - Ð'се было собрано из Ñ,,ерриÑ,овой крошки оÑ, ОС Ñ,елевизоров и прочего? Ð'се эÑ,о было засыпано внуÑ,рь двуÑ... карÑ,онныÑ... Ñ,рубок- Ñ,ак ведь?
[15:31:03] vadim.ganzha: Народ - морочиÑ,ся сÑ,авиÑ, кольца из н2000 и ничего не получаеÑ,ся, подÑ,верди или опровергни!
[15:56:57] tiger2007: да , Ñ,ак и есÑ,ÑŒ Ñ,,ериÑ, был оÑ, ОС
[15:57:12] vadim.ganzha: Спасибо!
Use Google translator!
Ganzha
Quote from: TEKTRON on November 25, 2011, 04:53:11 AM
Ehrlich, The way I read it,
Or am I not reading this correctly?
tiger2007, here's a quote;
  Cardboard tube outer diameter of 50mm, inner tube - 40mm between ferrite broken by  HV Flashback and Yoke.  foil on the outside, inside the foil.  Length of 140 mm.  winding on one side of the pump turns 50 row wire 2mm, it served 50 Hz pulses 12c. Coil pickup - the same wire coils 20 on the other half, her lamp 12c 10 Watt.  spark on foil internal to external useless when the light is sincere in full heat, power consumption drops by a quarter.  Good luck to all is simple.
(check I have improve Gogles tr)
It was taken from Russian forum - Tiger published some of his experiments and someone asked him about this tube with ferrite - Tiger answered - that it is/// I have added skype conversation to clear this matter finally
verpies
Quote from: John M on November 24, 2011, 09:57:14 PM
Note that the two larger coils are wound opposite one another which would cancel the H field, possibly no lenz effect.
No, the direction of the windings has no influence on the polarity of the induced H-Field because its direction is determined by the direction of current and the direction of winding. Current will flow in opposite direction in oppositely wound coil, but the H-Field will be the same.
So Lenz law is not defeated at all and the induced current in the receiving coil creates an H-Field that opposes the field of the driving coil and aids the field of the other receiving coil.
Ganzha
Meanwile someone has a rest Tiger is still in progress - welcome to his new video about Magical  Mistery Yoke from old USSR TV sets!
http://youtu.be/71q1DPsFemw
