0 Members and 165 Guests are viewing this topic.
stivep
new video #4
http://www.youtube.com/watch?v=iUHfIaWqzR0
I have found few errors and I will delete video and post   one with corrections !!!!!
Wesley
forest
flyback driver without easy adjusting output frequency can be used only if we know exactly how to tune to resonance, but even Tesla used tunable circuits because it is almsot impossible to match all parameters without adjusting
verpies
Quote from: forest on November 29, 2011, 04:18:02 AM
If precise frequency control is important then use the TL494 with an H-Bridge output stage, like Meggerman has suggested
Quote from: MeggerMan on November 28, 2011, 06:27:44 PM
Another way would be to drive the two mosfet gates with a TL494 push-pull IC so that you can control the mark space ratio and hence the driving power to the primary winding.
MeggerMan
Quote from: verpies on November 29, 2011, 06:52:12 AM
Attached is a picture of the TL494 on a small bread board.
I also have built this permanently on a vero board with a range of caps that can be jumpered in/out for a range from 50Hz to about 900Khz. I will post a picture of this one later.
Red/blue on 17/18 are the two push pull outputs.
10K trimmer on 6-8 is duty
100K trimmer on 22-24 is freq.
0.1uF yellow cap on 7-9 is frequency range cap (swap out for a different range).
I think this was set to go down to about 60Hz but the cap could be changed to allow it to go lower/higher.
My next step is to strip the HT coil + ferrite yoke out of an old TV thats in the loft.
@Wesley, which is the better design to work with: deflection Yoke or Tube + ferrite?
