0 Members and 381 Guests are viewing this topic.
ramset
Thanks Grandma
verpies
Quote from: ramset on November 30, 2011, 08:08:25 PM
I put a light bulb in water and ran some tests !
Can't see why this method Could not be modified to test Wesley's watt usage??
It could be if the light bulb heater was calibrated first with a known DC current, because light bulbs convert electrical power into non-heating radiation besides heat.  A non-incandescent resistive heater would not have this flaw.
But despite that, it is a much better method than eyeballing the bulb's brightness. It's even better than a SWR/W RF meter because it measures power down to DC.
Water calorimetry is undisputable but as a lab instrument  it is unattractive because it's so sloooow.
A light bulb locked in a paint can with a photodiode or a photovoltaic cell can measure the power level almost immediately and from high frequencies down to DC (calibrated with known DC current, of course)
a.king21
I cannot understand what all the fuss is about!?
Is Wesley asking you to spend hundreds on equipment? NO
Is he asking you to spend weeks and weeks of your time? NO
Is he asking you to make expensive trips abroad?  NO
Is he asking for hours of theoretical analysis? NO
All he is asking is for a couple hours of your time to wind a special coil.
Most of you have your own spark gaps anyway, from Tesla stuff etc.
Just build it, THEN ASK QUESTIONS.
That's what I am doing.
SIMPLE WAY TO PROVE OVERUNITY:
Run the experiment from a 12v  car battery via inverter.
Instead of a lightbulb use a correctly rated diode to pulse charge the battery.
1 Measure starting voltage on battery with all equipment OFF!
2 Run experiment for 15 minutes.
3 Wait 5 minutes
4 Measure voltage on battery with all other equipment OFF.
No need for fancy equipment or scopes.
If battery voltage at the end is higher, then you have overunity. Or more appropriately C.O.P. > 1
SIMPLE.
Legal Note: This post is for information only. Do not perform this test unless you have the necessary permits.
I accept no responsibility whatsoever if you choose to do the experiment.
High voltage is dangerous and can kill.
Batteries may explode if pulse charged.
If you perform the experiment it is on the understanding that this information is for educational purposes only.
Do so at your own risk. My advice is DO NOT perform the experiment.
End of legal note.
So all the fancy equipment you need is a multimeter. :)
ramset
The team has everything they need right now to run an In out Test
I did a trial run....
Drop the bulb in one liter of water [standard BTU Calq]
It works just fine, and it will take 2 minutes to try it Wesley!!
If you want I'll bring you my set up  we run it till your input uses .01 KWH on the meter[10 watts]
And check the temp against My Baseline.............
Here
Peter Daysh Davey Water Heater QuerySimple!!
If all we can do is light bulbs right now??
So what..... we can do "SideWalk" calorimetry!!
Yeah.. I know we waste the light [who cares]?
It will answer a ton of questions!!
Chet
You want this test set up ? I can have it to you in 20 Minutes...
Chetkremens@gmail.com!!
Thanks Grandma
stivep
Quote from: ramset on November 30, 2011, 09:56:08 PM
Here
Chet
thank you Ramset :)
Wesley
