0 Members and 354 Guests are viewing this topic.
hartiberlin
Quote from: stivep on December 01, 2011, 12:23:24 PM
WARNING:
This was a test only
results:
The picture OF MINE - OF  PICKUP COIL below  loads with no problems.
I have one schematic that I'm trying to post on this forum DOES NOT loads
Is says
Failed Security check.
HARTBERLIN PLEASE REACT
Wesley
Hi Wesley and all,
the new forum software seems to have a better checking algorhythm build into
it and sometimes also the caching has probems.
I will soon move to a different hoster in the new year, so I hope the
problems will be solved then.
Just be sure to post only pictures with no long names and alsways like this:
or simular
If the picture will not be stored try to reencode it to a different JPEG quality
with freeware programs like Irfanview.com
So just set the JPEG Quality there to 80 % and then save the file again.
This should help.
Sometimes JPEG üicture files have different headers with additional informations
and this might confuse the forum upload software..
Hope this helps.
Regards, Stefan.
verpies
Quote from: wattsup on December 01, 2011, 04:56:30 PM
Hmmmmmmm. I was running it for like 15 second shots, not more, all during the early morning and when I returned from the office. Then my son Carl gets home and I call him and his friend Morel down to my office to see this Flyback Chopper rip some nice sparks. Anyways long story short we got to talking and I left it running for a good 3 minutes or so. Too long. It just stopped and won't start again.
Most likely that small flyback transformer could not take that kind of power.
First, check the transistors first with a multimeter. Desolder the transistors and measure them using the diode-test setting:
1)  between the Gate and the Source - the reading should be as with an open circuit (both directions)
2)  between the Gate and the Drain - the reading should be as with an open circuit (both directions)
3)  Short the Gate to Source, then measure:
   a) between Source and Drain -  the reading should be as with an open circuit (in one direction).
   b) the measurement in the other direction should be 0.6V because of the internal diode between the Source and Drain.
   c) Repeat the measurement in pt.a on 1Mohm setting - the reading should be as with an open circuit (in one direction).
4) Check the D1, D2, D3, D4 diodes on the diode-test setting.
If all semiconductor components are OK, check the C1 with a diodemeter and an ohmeter in the 1Mohm range and if it shows an open circuit (as all good capacitors should) then assume that the secondary of the flyback is fried and go to a garage sale and buy a big old CRT TV that you can cannibalize for its jumbo flyback.
Acca
http://www.youtube.com/watch?v=0OCIHEVRXX4
MAGNET VORTEX SPIN VIDEO by Al aka "(Acca)" showing an un-accounted vortex that is validated through a very simple demonstration.
I have been on this Kapanadze forum since Wesley posted his First video in Polish and that is what caught my eye on his YouTube channel I Did build the first Naudin/Kapagen device and found it to be VERY un-safe and I removed that video from my channel, I had over 150,000 views over a year,  now that is over,  and now I am building the NEW version of the "Kapanadze device".. I only post when I have very important things to say otherwise I stay silent, I will post the first of may clips by tomorrow...
Attached are two photos of the ferrites that I got from a surplus store here in Denver Colorado that I will build the coils on top, with a
plastic pipe covering the ferrites, I have used super glue to attach the pieces in one unit.. I will show in the video clip tomorrow on my
youtube channel.. Al..
This video clip is from my old YouTube channel under the name of Magnetflipper that was deleted, in October of 2011. This was made to show through a very simple method that magnets have multiple fields and through this very simple method. The magnet is in some salt water on a metal plate with a thin insulator under the magnet, a 12 volts DC is applied to the magnet through one terminal to the side of the magnet and the other terminal to the metal plate. The magnet can be positioned any way with the magnetic poles on top or bottom as to show the dis-association of the water into oxygen and hydrogen by the break down through electrolysis. The bubbles will come off the the chrome plated neo magnet and begin to be picked up by the magnetic vortex in the frame dragging of the bubbles, then showing the spin of the magnetic field. What I understand is by applying a voltage potential to the side I negate one of the helical double vortex fields and what remains is the spinning field. I have also placed an iron slug of the same size in the salt water to demonstrate that this condition of the spinning vortex is NOT made by the current flow, as the iron slug shows NO helical spin at all !! I have re-loaded this clip for Overunity forum people who are working on the Wesley team for the Kapanadze device... There are other copies of this clip on the web from months ago. I made this clip and Magnetflipper was my old channel that is no longer up.
Please make copies and download this clip as I give full permission to Re-post and copy to all people .
Al...     aka (Acca)
stivep
Quote from: verpies on December 01, 2011, 04:03:13 PM
One of my students (a nefarious hacker) says that your professional is wrong.  See:
http://technet.microsoft.com/en-us/security/bulletin/ms04-028
Microsoft wrote:
"A buffer overrun vulnerability exists in the processing of JPEG image formats that could allow remote code execution on an affected system. The vulnerability is documented in this bulletin in its own section.
If a user is logged on with administrator privileges, an attacker who successfully exploited this vulnerability could take complete control of an affected system, including installing programs; viewing, changing, or deleting data; or creating new accounts with full privileges"
This student says that this vulerablility was compiled into many other non-Microsoft programs and is still exploitable.
Additionally a new 0-day similar png vulnerability was recently auctioned off.
Thus, a spyware executable code is definitely possible in photo/image files.
Thank You Verpies
Acca
QuotePlease make copies and download this clip as I give full permission to Re-post and copy to all people
Thank You Acca
T-1000
It was drawing 12vdc at 5.2 amps off my power supply before it stopped. When i first started running it, it was drawing 12vdc at around 2.5 amps. I scoped the drain and at 1mS, you can see two cycles per division.
It draws lots of current if is not running in natural resonance of flyback transformer or secondary coil is attached to low resistance closed circuit.
Also plain sparks from flyback shirt secondary coil what cause it to overheat.
In our circuit the flyback transformer do not get shorted secondary so we do not kill dipole.. ;)
