0 Members and 57 Guests are viewing this topic.
Pirate88179
And let us think, that the great son of Georgian people (in abbreviated form [VSGN]), to us [vparivaet].
1. This is the switch with the timer, which has as a goal to open external nourishment with reaching of the regime of [samopodderzhki]. Is executed this dully as the time delay, after which, the device guaranteed will be able to support itself. For the understanding principle pianos it does not play. Nothing new.
2. Capacitor. Well capacitor in this part of the chain itself is requested to [but] by that called as damping capacity. Of another role on this part of the diagram I to it lead cannot, [umishkom] she did not leave. True, the lines of connection, divided into two, drop the seed of doubt. But we will thus far choke it.
3. Points. Remarkable name. It not to in no way identify. But in the annotation to the figure, the author makes reservation 3- points (as the distributor of engine) Georgian SLANG in the Turkish manner. To there remains only surmise, which is concealed under this mysterious determination. The first thought which occurs of [vsvyazi] with the definition “as distributor”, this is switchboard. Since “cylinders” only one, then the task of this switchboard not to switch between, but to include to turn off, to lock to open. For example in Gray “at this place” stood multivibrator. And name itself “points”, suggests, that this is actual it, and at the output in it “dotted line”. Let us assume. That this so there is.
4. High-frequency generator. Here like customary term and separately to be steamed does not be necessary. But however there are slippery places. Why “multivibrator” is shown separately? But if you is usual person, and not [VSGN], the like to simple dull straight logic it turns out that this “points” excites the fast and well certain outline of the high frequency. Here although kill, another understanding i as yet do not have.
5. Primary filter. In the pancake Clinton. Problem placed [VSGN]. What it is filtered? The high frequency, which is manufactured in the high-frequency generator. But from what?.
But does can this [VSGN] the brain it does steam? What is the simplest elementary filter for HF? We place in this place of [konder], thus far. Well in order not to climb into highest electronics.
[Vooot]. And through this [konder], appropriate to rating [esssno], this all will be given to coil 6. Vaguely is depicted [skhemka]. True, until is evident from where [ays]. Came out thus far completely usual chain, we have similar it is many. Well let us nevertheless draw it in order further greatly not to be confused. In this case switch with the timer let us throw out [naffig] so that it would not dangle under the feet.
Here is [taka]
Here [taka] here of [khrenka] came out thus far. We go further.
We look chain two (or second?)…
hartiberlin
Pirate88179
But the second chain, because of the strong magnetic field, accepted from the first coil, creates the difference of magnetic pour on between the coils. The difference of the magnetic field of that appearing between the second coil and the first coil, is stabilized with the aid of the frequency regulator in the limits of this chain.
The second chain consists of the second filter, the frequency regulator, second coil, second frequency regulator.
Well let us begin
Well let us begin on [tsiferkam].
8. Second filter. Since we did take upon ourselves courage to replace primary filter [kondyukom], why to us to be troubled to make this again? Let us make.
9. Frequency regulator (regulator). To [bu]-[bu]-[bu]… Certainly, it is complicated so here unambiguously to say that this device represents from itself. But here something “sucks under the spoon”, that this is precisely that discharger, which on
Размышляем по паÑ,енÑ,у Тариэла Капанадзе    demonstrations we observed as the work of [ochumelykh] curved knobs. Let us assume. (this not final opinion, I simply attempt to transfer this block diagram into [printsipialku]. Errors are not excluded). But let us thus far leave this as discharger.
10. Coil is second. Here without questions.
11. Second frequency regulator. Here, it seems, by discharger not to [otmazatsya].
But [vobshchem]- that here still is in prospect to explain that it occurs so that with such parameters of coils, we at the output would obtain commercial frequency. Therefore let us thus far hang up this device in air with the sign (?).
The stabilizer of the difference of magnetic field with the aid of the frequency regulator, this chain also converts energy, which moves independently into air to the second coil, which stands at the method of this electrical energy. This electrical energy, formed by the second coil, regulates the necessary frequency of output (220 V - 50 Hz or 110 V - 60 Hz) with the aid of the second frequency regulator, which stands at the output of coil.
Similarly, nevertheless it is necessary to recall that proposed by winter about the version. It is probable that energy varies in the primary and second chains with the difference in the frequency in 50-60 Hz. And for this they serve the chain of the maintenance of frequency. Since two pendulums (they are borne in mind mechanical), suspended from one wall after a certain time come into the synchronism. It means necessarily to artificially support detuning.
The detected beat frequency guarantees to us the absence of the influence of output on the entrance. This is positive moment. Negative in the fact that until is not entirely understandable as this to ensure. But I assume. That by the joint efforts we must wipe nose this [VSGN].
Let us try to draw [printsipialku]. With exception of incomprehensible moments.
Pirate88179
Here this [fignya] thus far came out.
This produced electrical energy is transferred to the assigned load through the output leads. Through the output cables the device feeds itself by the produced electrical energy. The mentioned process concludes after 1-2 seconds after device it will be neglected. After this, the switch of timer, which stands at the entrance of device disconnects storage battery. And device produces energy independently.
Good and optimistic finale. ☺
flathunter
@ groundloop
It says ''second frequency regulator''...there is a ''first frequency regulator'' on the patent also.
Any short translations i dont mind doing  ;D  Might as well help the onward march to free energy!
Good luck guys!  This is way way way too complicated for me - i'm still playing with my joule thief for 20 leds and several lifter variations, but i'm with you for any translations.
