0 Members and 170 Guests are viewing this topic.
energia9
Quote from: semenihin-77 on December 07, 2011, 02:12:12 PM
no comments  http://www.youtube.com/watch?v=NXyo5ViR9C8
What is the bulb rated at?  60 watt?
if its true and you are not a liar and you are being honest, and not a man of attention.
Then i know that with proper measurements, if it is truly 6 watts that s been drawn from battery and not more,  then well done and big hand shake.
we can not light a 60 watt lightbulb to this brightness, with 6 watts it is not even possible to light it to any brightness..
If what you state is true, and if you want change and not ignorance, then better publish everything in great detail.
Well done again if its true.
xenomorphlabs
I need more ferrite rods. Since my Katcher is bigger than Delamorto's i think more ferrite needs to be in the core.
Welding rods as core material won't work. My lamp only lights up with the 2 ferrite rods that i put in the core.
semenihin-77
Quote from: energia9 on December 07, 2011, 02:57:15 PM
This is true, everything is visible as it is.
Moreover managed by removing the resistor from the circuit to reduce the consumption of up to 0.45 amps, this is not the limit, if it were possible to pick up the transistor, then .......
This is what everyone expected, Kacher pumps more energy than he consumes. But in the scheme is a secret, but it seems that everything is so simple, as we say in Russian - to handle the details of the file. ;)
xenomorphlabs
Quote from: semenihin-77 on December 07, 2011, 03:50:30 PM
Delamorto, do you own a LCR-Meter and could measure the resistance and inductance of your secondary coil?
Or do you remember how many turns you used?
energia9
i dont quite get what you are saying when you say , but in scheme is a secret, but it seems that everything is simple.
if you dont share the secret,
Good bye then.
we need all info otherwise we can not do anything apart from watching your videos. if You want others to replicate dont speak in methapors,
speak in scientific language,
