0 Members and 170 Guests are viewing this topic.
Shokac
Quote from: Jimboot on December 07, 2011, 07:53:47 AM
Been messing about with SEM 77 device with an mje3055. No luck though. Running at 24v 700mA. Ferrite gets hot but that's about it. Using a varicap out of an old valve radio. I think the specifics of the primary and maybe the nature of the ferrite are required. The inductance of the primary would be good at least SEM if you know it. Thanks for your contribution.
Sem77 use Ferite only for trigering transistor
wattsup
@all
Dual flyback setup will be ready tonight. lol
OK, I think I will have to open a new thread. Pages here are advancing too fast and we are losing the concentration. I will ask @stefan to have moderator status to keep only the pertinent information otherwise we will again get lost. Seems like thread direction can turn on a dime on this thread.
@ronotte
Please don't think no response means no interest. It's just that not many here can actually comment on something that is this new. Also, please realize that up till now the WNYg has only used their flyback for the shown effects even though I had tried to explain the importance for them to try with other flyback models. There is surely something there that makes this more then just supplying a known HV level. Also, maybe your HV level is not high enough. If I remember it was going from 0 - 9kv. Maybe you need higher level.
If you have a local TV repair place, do like me. Yesterday I stopped at a TV repair place and asked them if they had a box of used flybacks. The guy took me to the back and they had a big box full. I managed to find two identical, plus one identical to the one I had dissected but broke the ferrite so now I have the identical, plus another much bigger flyback. All for 10 bucks. lol Plus the guy was happy to see someone come in and ask for this because they have been collecting them for years.
@virpies
About your list of procedures, again, it did not go unnoticed but again not many can comment on that. All the yoke procedure seems illogical to me anyways. Find a frequency, then use it on another coil but the resonance winds up being way out of that range, so what is the point of finding the first frequency, etc. Seems like alot of doodling for nothing. Sorry to say.
@Hope
My sincere condolences to you and your family.  When my dad passed away I was so sad that I decided to write a little bit of music but this time using only my computer program (Power Chords) which is a guitar based program. Anyways, it's just a musical interlude that loops as life does. You can listen to it here if you feel like it. The sound is very electronic but what can you expect from such programs.
http://purco.qc.ca/ftp/Wattsups%27%20stuff/songs/
click on bye-bye.mid
wattsup
xenomorphlabs
@Jimboot: Did you get a faint glow of the filament in your bulb?
It IS also about the transistor attributes concerning the switching behaviour. (Unqualified objections from certain people aside)
What Delamorto achieves is a pretty high switching frequency.
The 3055 has a transition frequency of 3 MHz, i believe that Delamorto establishes a much higher
resonance due to his KT transistor having an ftrans of about 20 MHz. The people that experimented with Slayer's Exciter also found that different transistors
performed differently in regards to Streamers and have settled with MPSAs and 2222s.
To talk in numbers my secondary has 91 Ohms (~0.15mm wire dia). This might be not enough turns.
I think 150 Ohms is what most Kachers are having. I do not get the end of the primary to emit streamers
without touching it with a screwdriver. Driven with 24 Volt.
The red primary in Delamorto's Kacher seems to be 2.5 turns from what can be seen in the videos.
Something that i left unregarded until now is what coil former material did he use? It's white,maybe plastic?
It could have a different dielectric property and it is quite thick, since there might be a capacitive effect present here. I just used a thinner edged PVC pipe.
verpies
Quote from: wattsup on December 07, 2011, 08:57:34 AM
Well, I did not invent the tuning procedure, I just cleaned it up and want to clear it up all the way.
At first, it was illogical to me too but then it stopped being so, once I started suspecting that its main purpose is to create two waveforms 90deg. out of phase in the 1-turn and 50-turn windings.
When these two windings are fed from one common source (the HF Signal Generator directly to 50t and by stray mutual inductance to the 1t winding) then the current in them can be 90deg. out of phase only when both windings are not at resonance!
In fact one winding has to be more capacitive and the other must be more inductive in order to accomplish this, and this is exactly the relationship between the 50t and 1t windings.
Furthermore, the avoidance of the "ringing waveforms" in the tuning procedure seems to support this proposition, because the ringing frequency is the resonance frequency.
Look at my previous post below:
Quote from: verpies on November 24, 2011, 08:05:35 AM
If my hunch is correct than the goal of the tuning procedure is to create a rotating magnetic field inside of the ferrite.
I wish I could just ask Wesley for a simultaneous 2-ch scopeshot of the waveforms in the 1t and 50t windings while the device is tuned and driving that 150W load, but I think he does not like me because I ask hard questions and he will not do it.
If Stefan gives you the moderator status (an idea which I support for Wattsup and Baroutologos) then I hope that you will split this thread into three new ones:
1) STAAAR's Yoke Device
2) SAAAR's Tube Device
3) The Kacher device
...and leave this thread only for  Kapanadze's dvices.
jbignes5
Quote from: verpies on December 07, 2011, 09:34:08 AM
No it is not. It should be the frequency of the spring you create in the ferrite material via the interference pattern of the two waves although they are bound loosely to each other. This looseness can be modulated and directed by the Iron or soft steel. Iron/soft steel probably being the best choice. If we go back to the example I gave of an intensified external field of magnets we can see that mere voltage can show the underlying patterns. What I saw was very much like a spring around the magnets. When you play them against each other it causes them to vibrate, accelerate and form interference patterns both in length and breadth of that spring. By hooking wires(coils) around it it acts like a fluid pump in the case of the yoke. One end of the coil is lower voltage then the other. This causes a squeezing of the internal network increasing it's permeability and speed or force. It also draws in more lines from the surrounding network in this process.
He just reported the effect he wants replicators not endless school taught questions. Listen we were only taught half of what we could see. The other half got thrown away because at that time it seemed useless. Just like static electricity and high voltage.
I agree that they should be moved out of this thread. But the mods need to be the ones who started the additional methods.
