itsu
QuoteSo my question is how can I find out how much wire length I would need to produce 3400pF with a given wire AWG.
Hi wattsup,  you can use this calculator:
http://deepfriedneon.com/tesla_f_calchelix.html
Regards Itsu
sasa640
hello everyone from serbia
my first coil two light bulbs 100+60 watts lightning, I have to make proper measurement to prove it, is it making extra energy. I use 16 mm ferrite core length 400 mm and trafo from microwave oven. But since I do not know anything about el. power this is amazing for me. I just followed videos from youtube and forums and it is working now. Needs a lot time and effort to make it useable for everyone. And I also need to build flyback to make it autonomic.
http://youtu.be/ek92QiKWshs
xenomorphlabs
Quote from: wattsup on December 08, 2011, 08:44:02 AM
I would say the outer fat coil of 6 turns is his capacitor. It is positioned way too far from the main coil winds to be working at inductive or close coupled levels, hence it is far enough to only utilize the coils capacitance and still appear to be used as a coil for the functional deceptive value.
It is made out of coax cable in the green box, and so is it in the newest device.
What he calls "primary" in the aquarium video looks like a tubular capacitor with
inner aluminum tube and outer copper sheets. Romero has pointed that out too a couple of pages ago.
The fact THAT TK still calls it primary which one would only use if to describe a transformer action
is interesting. So either that tubular capacitor still exerts a magnetic effect on the secondary (which i could not explain at all to be feasible) or he is looking at the whole thing as an electric field transformer with no significant magnetic component. But even for that the distance between them is too large.
Keep in mind that if he wanted to maximize a magnetic effect in that transformation he would
use iron or ferrite in the core of the horizontal secondary.
Instead he uses non-magnetic brass, which reduces the inductance of the secondary even.
This puzzles me for quite some time now.
That and the fact that he uses crossed windings for cancellation on top of it, is a strong indicator that
he seeks to create negative inductance in the secondary while maybe only wanting to excite the background
of the windings with high voltage. The same method is also described in "certain" files :)
@Sasa649: This is a Kapagen replication?
One note concerning your video. Forget about the clampmeter (for measuring current).
It does not give correct readings at high frequency operation, it is designed for 50Hz only.
That is the most common measurement mistake with these devices.
MasterPlaster
Quote from: sasa640 on December 08, 2011, 10:08:18 AM
Thanks for the video. It looks very promissing. I look forward to your subsequent posts.
jbignes5
Hmm.. Very funny.. Is that clothes line connecting the useless connector just above the dual spark plugs? ROFL
heh.. Well I wouldn't give those guys the time of the day lol. Just keep with it.
