0 Members and 175 Guests are viewing this topic.
bolt
Quote from: semenihin-77 on December 08, 2011, 01:48:57 PM
For those who believe:
http://www.youtube.com/watch?v=q8XBxcyznOs
http://s54.radikal.ru/i144/1112/b5/556d48540cdf.jpg
http://www.youtube.com/watch?v=_57JaX5GeXQ
I like it the COP looks around 4 :)
Perhaps you can get hold of a MRF454 NPN RF power transistor that is usable to 30 Mhz and 100 watts.  Need a bigger Tesla coil for 400 watt load!
Fet use is difficult but possible to use IRF840's good for 60 watts RF @ 30 Mhz. Requires accurate biasing and 15v zener to protect the gate.  You also have a lot of stray RF leaking up the battery supply lines. Better filtering chokes would keep more going up the Tesla coil as you could be wasting 20% right now.
baroutologos
Hello all and sem77,
Last days i spent in my free time experimenting.. i had some fun but poor results in comparison.
i always had that thing with kachers, namely slayer's exciter, jonny davro's circuits, etc I always, no matter what, get results inferior with same materials at equal power rating... almost mystery to me.
Anyway, i tried almost everything. Aircore, ferrite core, trying diodes (even though the MJE15030 does not need any) between B-C, tried capacitance at primary coil, tried different L1 shapes, more or less turns, tried to ground the emmiter or not... anyway you got the picture.
Although, larger inductance always helps at enhancing oscillation by using 400HH soviet type ferrite rods, or 2000MM soviet rings. (rod works better) but still the high voltage end doe not spark alone and widely as the video show. at best it has a tiny streamer at over 25w of power using the big coil.
used extensively the o-scope. The circuit seems to works great, transistor ons-off as it supposed to etc. One thing to mention is that ferrite gets hot at the middle of the coil. propably gets saturated..
Thats all for now
dllabarre
Quote from: wattsup on December 08, 2011, 08:44:02 AM
This may have pushed TK to start thinking even more out of the box and he may have started experimenting using coils as capacitors.
Also, on the TK coil which is the output, any classical capacitor requirement (such as that in the WNYg device output) at that point would have meant more wires going into the green box, which there are not. So now I am more then sure he was using a coil as a capacitor wound on the same output coil so no extra inter wiring between the TK coil and the green box is required. I would say the outer fat coil of 6 turns is his capacitor. It is positioned way too far from the main coil winds to be working at inductive or close coupled levels, hence it is far enough to only utilize the coils capacitance and still appear to be used as a coil for the functional deceptive value.
wattsup
I think you're on the correct path.  At least a path I'm traveling on now...
TK had what appears to be a coax cable in the outer copper tubing and we know coax cables make good capacitors.
Just an idea I'm playing with.
DonL
PS - I see others have mentioned this already....
semenihin-77
I plan to start production of desktop generator CE, as a toy for now. I make small Kacher only because a large I do not have cable.
Yes, the power output depends on the transistor while it is true, above its ceiling is not to jump. I have already said - this is just the beginning, the beginning of something big and global.
Now think how to make a self powering.
Delamorto
bolt
Quote from: semenihin-77 on December 08, 2011, 02:50:46 PM
Delamorto
We share the same vision! I would love to run two off 3ft high tesla coils CO-PHASED 1000 watt drivers for 4000w loads. BUT big problem for many people if this goes global you are in effect transmitting strong RF around 1-2 Mhz typical and in small number of usage may not be an issue but a SERIOUS problem if everyone starts to make these devices for FCC regulations etc is illegal in many countries. You will get "men in black" knocking on your door. People need to be aware of this when making spark gaps systems  and large antennae you will be transmitting for thousands of miles!
