0 Members and 206 Guests are viewing this topic.
semenihin-77
A tepr importantly, actually works and without ground, a little less brightness of the lamp, and ferrites are not so important, they only need to start from a low supply. If the power is 20 volts ferrites are not needed.
Delamorto
garrypm
Hi Delamorto,
Thank you so much for the work you have been putting in and demonstrating for us.
Please, may we have more exacting details to attempt replication.
Thanks, Garry
forest
Quote from: semenihin-77 on December 09, 2011, 02:49:03 AM
Delamorto
What is the actual schematic you use ?
Jimboot
Still no luck semm77 on your device. I'd love to know the actual dimensions of your primary coil. My copper gets hot as does the ferrite. Lots of great plasma effects but not performing any better than a standard slayer exciter. All my exciters that run have a primary inductance of over 1000mH love to know more about the length & diameter of your primary. Thanks. Is the copper pipe 19mm - 3/4"?
jbignes5
Quote from: Magluvin on December 08, 2011, 11:09:55 PM
Thanks for hanging in there Sem.  ;]
Xeno
When I was about 8 years old, my Dad got me 2 electronics kits from a guy that worked for him. Its funny at that age with the things one comes up with.
My crystal radio circuits needed ground to work. But, I was tired of poking a post in the ground to make it work away from home.  I was 8  ;]
I experimented with grounding to metal parts. I found that I just needed something to ground to, a pipe, a few feet of angle iron, a pan.  ;]
So, it is the need for a reservoir for the AC circuit to act upon.  The larger the (suspended in air example) pipe/angle iron/pan, the better the signal from the crystal radio. Like a single plate of a capacitor, as in the globes atop of tuned Tesla coils.
A good earth ground did give better signal output than the pipe/angle/pan, but it worked impressively well.  ;]
Maybe the metal pot size could be a part of tuning, possibly.  ;]
Mags
This is exactly what Tesla did. He hung metal plates of differing sizes and connected them as virtual grounds to his one wire devices. Now think about doing that with a car? A Pierce Arrow car. A Big chunk of metal Isolated, *rubber tires*, from the ground but in inductive range of the ground. In fact Dr. Stiffler and lidmotor Did excellent discovery on the big block of metal as virtual ground. Well the metal does not just have a molecular weight to it. It has many other features as well. Including inductive and electrical features. These are still going even if they are not being used. You could say it idles most features then as it channels charges (heat) It transforms that heat into real byproducts. Listen if you had 2 antennas and you connect them together in such a way that always on the lower end it was heavy current and on the higher end it was very high voltage. Both antennas being perfectly balanced material wise. They both would have a standing voltage value right? Now put the bifilar coil in the middle and you should have a substantial flow right? When these two forms of current get added together via a load great transformations can happen in that inductive field If you know how to subdivide it or even multiply it. Gauge and surface area are key factors in the way one works with the flow going by us 24/7.
Someone knew this along time ago and tried to show us in permanent way of how this flow works. The Great Pyramids being the best know example of how to work with our flow we have here. The Pharaohs were gods for a reason. They could bring the flood every year! This was done via the Pyramids. The mere shape of them in that mass of crystal allows a flow change around the shape. The mass also touches the ground but does not conduct in the traditional sense because of the crystalline make up of it's matter. It's a flow divert-er and an accelerator. By pushing the field apart it creates a pull on the water in the ground to flow upwards. It also creates a huge division in the field and can be modified if you present a control charge into the structure. This process can also be used to charge the capacitor based on the position in the Pyramid or maybe just outside of the Pyramids.
I'm thinking this is where the mosses stories come in and he learned about the device and it's purpose. He learned how to maintain the source that was described to be a huge capacitor. One that could be varied by changing the level of the sand they used to fill it! Not only could the Pharaohs rely on the device it cemented his supreme ruler status because he did bring the water every year. Now this information was buried very deep and probably still is and they quickly turned it into a religion so the profits could keep the information as rituals and not have proof of what this really was.
So to get back to the subject Metal objects are subjected to fields all the time. It's how you use those fields and the potential difference you can create between two metal objects to draw on that difference and use it for your device. In this case insulated objects have a capacity to channel a certain amount of flow. Learn to create or divert a portion of that difference in that flow and harness that new flow and we have the perfect device.
