0 Members and 162 Guests are viewing this topic.
energy1234hope
Hi guys This is a youtube video of someone attempting a copy of kapanadze device
www.youtube.com/watch?v=ek92QiKWshs
xenomorphlabs
Quote from: semenihin-77 on December 09, 2011, 02:49:03 AM
A tepr importantly, actually works and without ground, a little less brightness of the lamp, and ferrites are not so important, they only need to start from a low supply. If the power is 20 volts ferrites are not needed.
Delamorto
@Delamorto
I am very surprised about what you say i must admit.
Ferrite makes no difference at 20 Volt? Or are not needed to reach an at least decent output?
If i take out the ferrite out of the coil former the 20W lamp turns off and i run at 24 Volt.
So there must be some factor in your device that is missing in mine that makes a HUGE difference.
Because i am lacking an adjustable capacitor i used a fixed cap of a few picos. Maybe the big
plates of that varicap do something?
Most probable reason is that your turn count on secondary is much higher than mine.
I used 0.2mm copper wire. If Delalmorto has more turns on a smaller coil former he must have
used 0.15 or even 0.1mm, which would push the resistance per coil quite high.
@Magluvin: You could beright about the metal ground having an effect on tuning. I am using an aluminum
plate at them moment, cuz Tesla talks about plates, but the metal pot has certainly more mass.
FreeEnergyInfo
FreeEnergyInfo
Quote from: verpies on December 09, 2011, 11:18:03 AM
Videos can be deceiving
soryyy....    this video ist internet    REFUSE ...  ENGLIH ....
DEJE Å IS VIDEO YRA EILINÄ– INTERNETO Å IUKÅ LÄ– ....  LITHUANIAN  ....
