0 Members and 145 Guests are viewing this topic.
jbignes5
 Not working yet but I'm formulating the way to do it now. From everything I am researching it is looking very promising. The Tesla exciter/generator/motor is the way to go. Thats my aim. I already have the iron for the field coils and 4 very strong neo's for the exciter. The only thing I am missing is the rotor and shaft+bearings for the whole unit. I want to make it that the motor has an aluminum housing to act like a heatsink because this thing will get hot. Just as air gets hot when you compress it so does this process. Heat is the driver and ultimately heat will be involved.
There have been a great many people who have used vortex technology to increase the output. Especially jet technologies.
I think the only reason nobody has gotten anything from a pmh is because there is no twisting to the field inside of the core locking it together. Once you get a flow you have to twist the field to get any action. Otherwise it is all one field, homogeneous. But when you twist the field it follows the rules of separation of like fields. when you also compress this field in the action of that twist it raises the value of one of the components of the field like voltage and likewise alters the current capabilities.
Take the pmh and then apply coils around the pmh and I bet you can twist the field like it was nothing and get huge values out of that twisting from a pickup coil that does not alter the field(bifilar). I think this is what Tesla did in this motor/generator setup.
It's pure mechanics after that point. Just like when we put 3 motors to drive a smaller cog in the center. You can get more power for less input that way.
Studying natural effects of the vortex has led me to understand what Tesla saw in his devices and how he made it so via his coils and one way pulses.
This vortex is also very very strong in the sense of spinning. I was helping some fellows with the no bearing Bedini motor with a Sphere magnet and as many satalite magnets as well as long as they were smaller then the main drive sphere. They all would spin and they could be harvested if you approached them from around the magnets, enveloping coils around the round magnets in other words.
This vortex is very large sometimes and is very strong in one of the degrees of a plane. Each degree set which is always 90 degrees out of planar alignment responds to one kind of pressure. Voltage being the light massive expansion type and heavy current magnetics. Magnetics is parallel and the electric field  is longitudinal. One supports the other and frequencies are just resonations or collections of both of these field lines in motion. Since the electric field is longitudinal it reaches out and is the connector of this network. When we super excite exposed wires they intensify this field and allow us to trace it. Even if the exciter isn't there the network is still doing the same thing.
Magnetic fields are much like the bubble rings we see in the water as well. Both bubble rings can be made but the reach is much different for each one. Magnetic shorter then the electric.
Both fields can be harvested from one reaction if you know the angles to approach them. We must combine the two back together to utilize the power of one solo source, with the other available to draw from (Antenna or virtual ground). With very high voltages you need to have an inlet of heavy current or magnetic lines to recombine with the high voltage that is waiting for it. Once you do that you get all the potential and then all the current that potential could have for that device's matter capabilities within that device. The recombining is an inductive one ans should include the environment in some way.
Coils of differing gauges when excited by the same field have way different responses. Throw in ferrite or iron and you have an amplifier or magnifier. Learn to couple with the iron in a one way style and you can take any amount of energy up to the limit of the matter you use.
Some more info on vortexes: http://peswiki.com/index.php/Directory:Tornado_in_a_Can
zhak
FreeEnergyInfo
Thank you for your openness
FreeEnergyInfo
спасибо вам за вашу оÑ,крыÑ,осÑ,ÑŒ
FreeEnergyInfo
Quote from: zhak on December 09, 2011, 12:58:30 PM
FreeEnergyInfo
FreeEnergyInfo
спасибo вам за вашу оÑ,крыÑ,осÑ,ÑŒ
AÄŒIU ...
SPASYBO ...
THANKS...
AÅ  TIKRAI  ŽINAU KAD NIEKAS IÅ  MUSU PLANETOS GYVENTOJU  MIRDAMI I KAPUS NIEKO NEPASIIMSIME...
TAD GYVENKIME TAIKIAI IR DRAUGIŠKAI ,JUK NIEKAS IŠ JUSU NEŽINOTE KADA MIRSITE ,IR KA TADA APIE JUS GALVOS APIE JUS LIKE ŽMONĖS ...
SÄ–KMÄ–S VISIEMS JUMS PAIEÅ KOSE FREE ENERGY ...
SÄ–KMÄ–S VISIEMS ...
LIETUVA.
Я знаю, чÑ,о никÑ,о из нас не умирающую планеÑ,у в могилу НИЧЕÐ"О не удаеÑ,ся ...
TAD жиÑ,ÑŒ в мире и дружелюбны, поÑ,ому чÑ,о оÑ, вас ничего не знаем, когда умираюÑ, и сжечь ТОÐ"Ð"А голову на Ð'Ы, как люди ...
Удачи всем Ð'ам искаÑ,ÑŒ для свободной энергии ...
Удачи всем ...
ЛИТÐ'А.
I do know that none of us dying planet to the grave NOTHING fails ...
TAD Live in peace and friendly, because NOTHING FROM YOU DO NOT KNOW WHEN die and burn THEN YOUR HEAD ON YOU LIKE PEOPLE ...
GOOD LUCK TO ALL YOU SEARCH FOR FREE ENERGY ...
Good luck to all ...
LITHUANIA.
www.halerman.narod.ru/TTCG/Kapanadze.htm
www.freeenergylt.narod2.ru
wattsup
@verpies
I just blew both flybacks. And the core on these were at least twice the size of the previous one. It ran for about an hour in 15 seconds intervals. Now I am really getting pissed off so I will wait till I receive my bigger flybacks. I think in these dioded flybacks the HV wire is so thin inside the coil that it really needs to be pulsed in a very controlled manner.
Soooooooooooooooooooooooooo.................... here is a question.
For a high voltage source, what if I just take a working cathode computer monitor (I have two that are not being used since the flat screens came out), and, I just splice into the HV line that goes to the cathode tube. Then just switch on the monitor and see what happens. Maybe I should point the screen towards a wall in case it blows. If that could work then anyone can have HV available with their computer monitor all in a nice ready made box. lol
wattsup
verpies
Quote from: wattsup on December 09, 2011, 02:00:34 PM
I just blew both flybacks...
Too much power and probably no safety capacitor on the secondary.
Re. the the HV form a monitor.  Yes this is definitely doable, I did it many times when I was a kid and was sparking away for hours. You can and should take off the "suction cup" (with the thick HV wire) off of the CRT.  Insulated needle-nose pliers work well once you fold that "suction cup" outwards.  Be careful because the CRT is a capacitor which can remain charged for some time.  Most of them have a megaohms bleeder resistor to drain it.
