0 Members and 31 Guests are viewing this topic.
Hope
Quote from: jbignes5 on December 10, 2011, 11:32:50 PM
  Once we know what the fields look like we can tune these glasses to that frequency and see all of the spectrum that the universe has and compare this to make sure it is real. Once we know these glasses work it will open our eyes to the miracles of the natural way. We will be able to devise new ways to interact with these fields because we will be able to see them.
Unfortunately these guys also made power generators from this film as well. They are gonna plaster everything with this stuff and lower the cost of energy to the bottom. Yes it will cost a few bucks to start but they should do well. Carbon nano tubes are the bling here.
Check it out: http://www.youtube.com/watch?v=FRJSGLvvDh4
I want a pair of those glasses ASAP. Kinda reminds me of the movie "Predator" helmet.  And BIG your right about when we can see all these fields will learn to use them.   What a fine article link.  Thank you        AND who is that guy and what is his company???
Also, a thought on the Cad coil,  has anyone tried weaving their wires where they cross each other??   OR has anyone used copper for the pickups and aluminum for the HV wires?
jbignes5
Quote from: znel on December 12, 2011, 03:20:20 PM
Jbigness, I've followed your work for quite some time on energetic and have learned a bunch from you.   You are quite a bit more advanced than myself and sometimes your posts are difficult to follow but I continue to absorb as much as I can.   Thanks for your contributions it's helped move me forward in my "quest for fire".
Heh. It's funny. My feeling is I'm bumbling and stumbling just like all of you. Thanks for the cudo's though. I know I might get repeating and cryptic at times but that is usually me trying to over explain the situation so that others might see this in my view. I am glad others get something out of my research.
I always say question everything. Even my views should be questioned and re-questioned. We will learn nothing if we don't look to why and how things work and openly discuss this.
jbignes5
Quote from: Hope on December 12, 2011, 03:24:13 PM
Yeah me too! Just imagine being able to tune those glasses to any frequency you wanted??
The white video shot of the world with all the scientists names on it says "NonoHoldings" Lower right. I suspect that is the company..
The president is named Justin Hall-Tipping.
http://nanoholdings.com/
I like the speech he did. It was from the heart. Although they are looking to make the next system of utility. But it is a onetime cost. It's my energy. This will revolutionize the world. EVERYONE will have the ability to be free finally. Thats worth my support. Energy will be free then and maintenance will be the only limiting factor. Quality of the product will also necessitate price. But in comparison you only pay once for  the hardware. Once that is done the sky is the limit. Our economy will rebuild very quickly and life will go on. After a bit of time the companies will go and we will retool our Humanity. Fix the unjust dictatorships and move in the Universe as a world unit. Everyone is a human on earth. Lets start treating each other as such and fix our broken world.
bolt
In ideal Kacher  you want the VSWR like 1: infinity where the voltage and the current is totally out of phase. Now you have pure electrostatic standing waves aka Scalar.
At the base should be max current and min voltage. At the tip will be max voltage and min current.
So any attempt to make the antenna longer or tuned will create excessive current draw and heat in the antenna or ferrite if used.
baroutologos
Hello all,
thanks for the feedback. it will take me some time to process the info.. :)
By the way, as well put, high frequency or RF has its own rules. I am not formally educated on those matters and i am very confident they have been detailed documented.
@kator,
yes, everything has its self capacitance as well as transistors. In fact transistors have quite a bit. You think i would not check that out first that thing? :P I have added a capacitor (400pf) between collector- emiter, base-emiter, base-collector (at 400pf oscillation dies, till 30pf or so works between B-C). Nothing changes.. the Kacher oscillates at same frequency being unaffected of those changes.
@znel,
Yes, the basic principle that a Kacher oscillates is coils' stray capacitance. You can estimate it if you know air coil's inductance and scope the free oscillation. According my calculations, 1,43mH inductance at 1.7 Mhz must have a stray capacitance of some 6pf. In order to run at 2,8 Mhz when forcing a ground node, normally you would require a 2.2 pf capacitance with same inductance coil. How is that? Capacitance dissapear? I can also add capacitors to free end of the coil between and ground. As long as a voltage node is enforced, those are not affecting the 2,7 Mhz.
Better restrain from theories unless you know excactly what is going on and have relative experience. Just do the experiment yourself, see the results. :)
Last and not least i am not aware of the concept of standing current. Voltage like a wave it is, is propagated by the speed of light or so, can be reflected and formulate nodes and antinodes. ok...
This is true also for current? Any formal document to read on that?
