0 Members and 55 Guests are viewing this topic.
jbignes5
Quote from: baroutologos on December 12, 2011, 05:06:45 PM
Last and not least i am not aware of the concept of standing current. Voltage like a wave it is, is propagated by the speed of light or so, can be reflected and formulate nodes and antinodes. ok...
This is true also for current? Any formal document to read on that?
Well standing current would be a body of water, wouldn't it?. I mentioned the way this stuff is standing. If we refer back to the plasma intensity experiment, they show you everything you need to know about this field. It is clear that the magnetic fields flow in the valleys of this electrical radial field. They condense there from the environment. The pictures in the video show it clear how this field is. It is spring like.
Also Tesla said that there is faster then light travel but that is of the network that proceeds it or Aether.
Jimboot
Quote from: woopy on December 12, 2011, 01:26:31 PM
Hi all
great input everywere here, bravo à tous ;)
Today i tried a replication of Sem77 (delamorto ?) system he posted in his youtube that he retired after receiving some comments.
And his shematic works. I don't know the efficiency, but this time i get real filament lighting in a 40 watt 220 volts bulb.
Will try to get some measurements and to change the copper tube. Notice i don't use a ferrite rod at all in this experiment. Perhaps i should try ferrite or a spiral copper tube etc...? :P
Lot of thinking tonight :o
Good luck at all
Laurent
http://www.youtube.com/watch?v=94yCfy8z4lc
Nice vid Laurent. Did you try the lamp that you use in this setup with your last setup? I'd be curious to know. Thanks
jbignes5
Quote from: znel on December 12, 2011, 03:14:01 PM
Here is another version I've played with that shows some very good results... it was an attempt to "mix" voltage and current.   I would change the 4148 to something better capable to handle current - these didn't last long.   I found the UF4007's to be a better replacement.
And how did that work for you? I am curious you used copper and aluminum. Was that solid core or multi-wire With my work in the crystal batteries I learned a lot of the standing potential of any item. As long as it has a surface it has to have a polarized field around it. Water seems to be the key in that field. But the metals provide the bias for the diode. Once it is on, it will induce moment from the environment. This movement is the condensation of magnetic lines from the environment twords the higher potential radiant lines Source.
When you got a ferrite core you can now induce movement in the copper by the now millions and billions of lines it channels between the huge inductance and ferrite channel. Because the coils of fine wire dictates the lines pattern radiating out from it or even into the center. If you think the field outside the coil is huge what would the field inside the coil look like? We know it is now solid and the magnetic lines are trying to go into the source channel (ferrite). Putting the copper plate around the ferrite is a very great idea. One thing I would try would be to try the 1 turn band instead of the copper pipe with slit. Different orientations like clock wise and counter clockwise bands could be made to try both. Silver plating would be very very simple!
woopy
Hi jimboot
i tried first the experiment with the bulb of my first testing where i got only plasma flash as per my previous video.http://www.youtube.com/watch?v=6ocPYYEv37g&list=UUi3fFZN1pwHTyM8H_nSxerg&feature=plcp
And with the Delamorto arrangement this same bulb's filament  glows as per normal electricity.
And i changed the bulb only for sake of  simplicity as i got a better bulb adaptor
No doubt Jim , the delamorto works very well
and last update     i disconnected the second wire of the bulb from the negative lead of the input and connected it to an antenna (around 10 meters of wire outside of my shop and it works too. than i connected the antenna to the negative and it was always better.  ouuchh  :o :o :o
That is to say that we are working in open circuitery   and the " don't kill the dipole " rule and it works   youpla!! ;)
let's replicate
and good night at all
Laurent
znel
Quote from: jbignes5 on December 12, 2011, 06:07:26 PM
I considered that one a success along the long road of learning.   It would run small DC motors, lamps and lots of LED's and ran with an input of 4.5 volts and 50ma.    It's along with many many others in my notebook.    The tubes were slit to reduce eddy currents, strictly air core.
I'm not sure what you mean by bands instead of a slit copper tube - seems like the same thing to me - unless your talking about a helical ribbon which would make sense to reduce eddy currents even more and put it on an angle that might intercept the magnetic field in the core, forming a single turn coil.    That actually sounds like something I should give some examination to...
Sometimes words don't form the same picture from one to another, I have a difficult time with word pictures - if I can see it in my mind clearly, I can build it...
