0 Members and 257 Guests are viewing this topic.
verpies
Quote from: wattsup on December 13, 2011, 06:58:54 PM
I am looking for a circuit that I can plug my FG and Power Supply to enable better frequency hunting then doing this fixed circuit pulsing.
This circuit is sufficient for a unipolar drive of a flyback transformer primary with a rectangular waveform:
Hope
Quote from: ronotte on December 13, 2011, 02:35:51 PM
Playing with my Cacher I noted some interesting features:
1 - I have been unable to rectify voltage for the lamp load. I tested both single diode and bridge diode unsuccesfully with and without a levelling capacitor. It is like impossible to drive any load different from the incandescence lamp. Simply the cacher does not work...not found a way to restart it in the new conditions.
2 - Open voltage (without the 240V/60W lamp) is very high, about 600V at 1.6MHz.
3 - Overall efficiency is for operation with only a small slitted Cu tube without ferrite core and a small ferrite core located in correspondence of the location of the 3 coils.
4 - marginal sweet points are with a 5 cm long Cu tube located approximately at the middle of the magnifier coil
5 - Equivalent operation (200V @1.6MHz measured on lamp load) found in using 2 x spiral coil or 2 x linear coils.
6 - any neon lamp put at 20cm distance from the device is lit without lowering the incadescence lamp luminosity.
7 - running the scope's probe along the magnifier coil does show the tipical 1/4 wave voltage distribution as expected. The node of course is at the magnifier beginning
8 - running a simple 1 turn wire loop shunted by a small lamp does light from about the half lenght of the coil and max nearing the initial node.
It is also interesting to note that irrespective of any variation I have been unable to rise the loaded voltage of 200Vpp. I am waiting now to receive the new transistor I ordered with a much higher ft for seeing if any difference.
Roberto
Perhaps this is why Tesla made special motors and such to use this energy.
Jimboot
Quote from: jbignes5 on December 13, 2011, 07:19:50 PM
@JimBoot...  Figured that.. Too bad. The rodin coil looked good..
ROFL yeah I thought so too.
baroutologos
In case anyone wondered, today i received my KT805AM transistors. Those seem pretty good. They should be also darlighton transistors since they have a current gain (at DC values) ranging from 1100-1400!
In oher words they can light a 10w 12v bulb (connected to a 12v battery) by using a 18K resistor at base. Impossible feat for whatever transistor i possess except darlightons of course.
MeggerMan
It was interesting to read some of the posts about the nodes in the secondary, where some have a current peak and others have a voltage peak.
At the moment most of the set-ups are solenoid based.
Solenoids are rather inefficient and according to wiki (Tesla transformer) the best transfer of energy from the primary to the secondary is around 85%. The primary and secondary have to wound and tuned with capacitors to work at the same resonant frequency.
So what if we make a toroid shaped winding?
This may be how the Steven Marks device worked.
In a video he demonstrated a 1.5KW self running generator then switched it off and chopped up the core with a hacksaw.
The core looked like it was made from a hard black foam material meaning he was probably using a loosely coupled transformer.
It all fits what is being done here.
So one test would be to see it the Tesla setup works in a toroidal config.
Its likely the field created by the small primary will bend round to follow the secondary.
Or is it the near field resonant inductive coupling as used in the Witricity devices.
http://en.wikipedia.org/wiki/WiTricity
I will need to wind a Tesla solenoid setup and test this first.
