0 Members and 709 Guests are viewing this topic.
pix
Quote from: forest on December 18, 2011, 04:33:54 AM
Take a bell and a hammer , with unidirectional sharp impulses of perfect synchronicity with long period between you can have perfect undamped oscillations from just a few basic impulses . That's what Tesla device is : a bell and a hammer. Hammer decides of energy input and bell assembly desides about the vibration undamped or damped quickly. All this is known for you and proved by Stiveip and Znel experiments (when receiver is incandescend bulb). This alone is OU. Exactly like pointed by Znel. Few watts used to charge capacitor at correct moment and sustained vibration prolonged many times then initial discharge. What is missing is clever receiver system without affecting transmitter. That's all ! Vladimir Utkin is right and my ideas too....   ;D
Yes forest, I also think this way.With hammer hit a bell once-we have a long decaying bell sound.Harvest that sound.
With hammer hitting a bell periodically we will have continous undamped sound. Locate many sound sensors around and collect that energy.This is only acoustic  example od what we could do electromagnetically.
For one unidirectional and short hammer hit- we have a long damped acoustic wave.Calculate total energy of that wave and compare it to energy of short pulse that triggers resonant event of (any) object- there is OU.
Regards,
pix
baroutologos
While experimentation has its merits and fun, have we actually given any thought at how (in a conceptual level) we could achieve overunity?
I have given some thought and i believe it could inspire experimenters or at least to find my way of thinking interesting.. so i begin.
We can imagine our OU device as a black box, that has a battery as a kick-starter and then its operation to be self sustained, outputing generous amounts of energy in the form of heat, radiation or electricity etc while it takes no fuel and its operation can be indefinitely prolonged as long as machine is maintained.
How can be that? Obviously the energy will not come from battery.. but from a source. This source could be,
- nuclear energy (of any special material, mineral etc)
- ambient energy (thermal, EM radiation, zero point etc)
- magnets
- electrets
etc
In the genre of OU alleged devices as Kapanadze, we can be sure that in the above contex, an initial chemical energy stored in a bettery is transformed to electric this in turn to a magnetic field or electric field, that in turn via an unknown mechanism will produce an electric or magnetic field with greater energy content that the initial pulse / stimulus. Excess energy is harvested and outputed + maintains device operation. ok so far.. but how?
I have given some thought from time to time and i present some concepts as:
a) An magnetic "transistor"
Imagine a material (e.g. ferrite) that under normal conditions is magnetically conductive. Imagine upon an application of a field or stimulus this to become non concductive. Absolute nessecity is the stimulus energy to be lesser than the magnetization energy of the whole magnetic circuit. This way, a permanent magnet can be used as an inexhaustible battery.
b) Magnetic "booster"
More or less in the same spirit, imagine a material (eg. ferrite) that upon it is wound a coil. Assuming the coil is passing I current and creates a feeble magnetization. Imagize to this coil to be applied a Field or Frequency that boosts ferrite's magnetic strength (hence energy content) by altering its permeatability. But this is not anly so... it has, furthermore this core to be "self-supermagnetized" without requiring additional energy input (to overcome the excessive new state self-inductance).
c) Coil "screening"
Imagine a coil that interacts with another coil via a magnetic material (e.g ferrite etc) but, their interaction is not linear and at best not reciprocal at all. Thus a coil can have a low self inductance, creating a B1-field of E1 content and this in turn via some mysterious screening mechanism to charge a matterial (that is wound another coil) with B2 field of E2 energy content. Prerequise is E1<E2.
On the counter part, extra energy could be theoretically extracted by harvesting excess E-field.
a) "Super-capacitor"
Imagine a capacitor inside a black box device that has 4 teminals. Actually its 2 capacitors one controlling the other. Imagine that the controlling cap has a capacity of 1uf and can be charged at 100volts, while in the same time the "controlled" capacitor has twice capacity 2uf and reaches 100volts. Assuming their voltage relation is linear at least, then we can harvest excess energy.
ps: quote of a fellow experimenter...
Quote"theory guides, experiment decides"
jbignes5
I had an arguement one time with someone I respected but that arguement didn't go so well. It was about the ball and input energy and no matter what I said he always responded the same answer. Now the only question that remain is leaving the initial bounce or rebound alone. Usually any form of trying to hook inductively to the source (bouncing Ball) would diminish the storage of potential in the form of a tensor on the surface of that ball. but if the ball had a magnet in it things would change a bit. We now have a mobile magnetic field generator. When you add motion to these fields they have a real inertia. Tesla referred to it as magnetic momentum. I think the momentum is very different then the typical momentum we typically see. Like the Leedskalnin PM Holder it has infinite ability to retain this pathway without loosing one ioda of its energy. The coils take care of that. Once this Pathway is established it has a great momentum in it's movement. It is biased on and held into a charged state by the Leedskalnin coils. Now the limit of the mass you are using is what is creating heat in the cores and that brings us to Bessemer steel.
Tesla said he was getting 2.5 times the response from his motors in power output. Thats what he gave to Westinghouse. You want to make an OU device then simply make a motor out of Soft Bessemer steel. Someone makes it and hardens it into wire for the Drills currently so there are people making it. You know the paint stripper kinds of wire wheel.
Even if not then it is a very very cheap process. Any smelter could do this process cheaply if they had a good buyer. The process was hard to perfect but thats a good smelters job right? I looked up Bessemer steel and there are quite a few hits one of which was the wire wheel manufacturer. They got to be making it then and maybe could ship us some soft version of a small stock of it, maybe a rod even.
Enfolder
Quote from: jbignes5 on December 18, 2011, 09:11:53 AM
Hello All,
Just a quick note of appreciation for this forum and the dedicated efforts to better humankind. Thank you for your work and for sharing.
On the subject of Bessemer steel, aka "Swedish Bessemer Steel": Here is a link to one supplier :
http://www.rotometals.com/product-p/swedishironrod.htm
I hope this helps,.. ;D
jbignes5
Quote from: Enfolder on December 18, 2011, 09:41:59 AM
Hello All,
Excellent now we got something to get and test. I hope this is the same stuff...
