0 Members and 23 Guests are viewing this topic.
jbignes5
Quote from: Hope on December 21, 2011, 08:32:02 AM
Then, as you suggest, we also are using a Rodin coil backwards?  What would you suppose about changing the middle of the Rodin center field into an antenna pickup and the output off the coil?  Then where would the bifilar coil be located.
On the inside between the antenna and Rodin or at what is now considered the inputs of a normal Rodin configuration?
Or is the bifilar just not needed.
Will the antenna need to be a Cad coil balanced in the mid field of the Rodin and perhaps the bifilar used as a tuning buck-er?
Odd thoughts, but easy to see when this flow is imagined as a fluid.
Yeah the Rodin coil has me stumped. I think the Rodin coil is only a bifilar coil so this would be used as a pickup but if you look at the electric field in the center of the Rodin coil it has the same effect as the Tesla tower coil. It imparts a twist to the electric field. I was thinking the Rodin was an excellent driver coil because of it's bifilar nature. What it is driving is what I suspect we are looking for. Maybe the Rodin coil is a wave guide so to speak. Wire it in single mode and short it out. It would then induce and squeeze the flow into a better shaped spiral form to flow by the flat bifilar pickup coil.
As a side note if a bifilar has no rebound effect on the source of a pulse then wouldn't that be the best diode in the world? At least from the point of view of the source?
Also if we look at this screw like action of the tall Tesla coil we should be able to pressurize it via a static inductive shield. Cone pointing to the lower coil. This should increase the pressure flowing by the bifilar pancake coil. Maybe putting spaces in between the inductive shield could tailor the flow to hit dedicated pickup coils. This might give the device some way of ramping up the power if needed on a switch in basis. This way we could have a basic power level that gives gravity like attraction and minimal systems. Any additional power levels can be switched in as needed and this will also open up maintenance while still running. The main coil will have parallel coils to make sure redundancy is built in to a single power unit.
The structure of a space ship should be round like our planet. This way the core is protected and gravity can be maintained twords the central core. Shields would be a natural phenomina because of the power setup. It will naturally radiate from the skin of the ship. Of course you could modulate that shield any way one wanted simply by small terminals extending from the skin of the ship. We could always use a static shielding as the skin of the ship. Then the Terminals would have to be emitters then but of course that can be controlled as well since the skin would be statically shielded from the internal ships structure.
Whew StarTrek moment rofl....
itsu
@ Jimboot,
QuoteI decided just for the hell of it to hook up what is essentially a closed loop av plug without a load to the primary where it is connected to the lamp. At the other end of the lamp was the standard aerial alligator clip.
i have problems visualizing what you did.
Could you perhaps make a drawing on where you put these diodes etc?
@ jbignes5
Ok, so the kacher coil is the primary, the driver coil the secondary and the harvest coil where the bulb attached is the third coil.
Thanks,  regards Itsu
jbignes5
Quote from: itsu on December 21, 2011, 09:28:24 AM
@ Jimboot,
@ jbignes5
Yeah kinda. The tall coil is the pulsing coil primary. This is what makes the twisting electric field. The flat heavy gauge bifilar coil is the secondary or load pickup. If you make a third coil it should be cone shaped with the small end pointing to the bifilar and should terminate near the diameter of the bifilar. Not close enough to short out, then close loop the cone coil. Moving that Tall Tesla coil in and out should be a way to tune it and the bifilar Pickup distance as well. All of these things need to be adjustable for tuning purposes. Tesla said this was a resonant transformer. It had zero losses well Near zero. 1-3% I believe. Because he had a hard time getting it that stable in resonant frequency.
With today's technology we should be able to accomplish this on a much smaller level as well. We are also unlocking the secrets of the nano world. This is evident enough  that there is a vast quantity of energy in this world, heck in our Universe. Once you know how to induce it, it can do amazing things.
One thing I read about Tesla is that he said there was no real limit to the energy summoned via this way. I'm not so sure about that. This stuff doesn't like to be compressed. It has the same hydrodynamic rules it follows about pressure and compressing spaces. Water is a mere shadow of this rule. It's a condensate of this network. It is what gives life its movement ability and it should follow the same rules of density all the way through to water.
"Spark gaps are the "brain" of the Tesla Coil. They are high the voltage switches that allow the tank circuit capacitance to charge and discharge. As performance of the spark gap switch is improved, peak powers in the tank circuit grow without requiring additional input power." *This is not a Tesla quote* by Tony van Roon: Nikola Tesla's Complete Autobiography
jbignes5
I wanted to touch on the Talk Tesla had in the court papers about 4 transformers that each could put out 44k volts. But he hooked them in such a away that he got a constant 44k with added pressure or constant pressure through 4 phases. I think he was filling the cap faster and faster with the spark gap as the timing device. A magnetic quenched gap would be adjustable and he protected the magnets with the best Mica he could buy. Once he had that he could drive the pulsations at incredible frequencies and a lot more force.
Tesla's problem and I believe he figured this out later is that he was trying to go outward instead of going inwards. When he did figure out this part he found some crazy things about this inward field. He once put his head in a coil and said see nothing wrong. But yet when he put in a metal it acted like normal and heated it up quickly. Well certain metals. This bessemer soft steel is probably the exception to the rule. Westinghouse relied on that for transformers.
Tesla talked about taking 4 phases and commutating them to have a constant pressure at 44k volts. Each transformer was capable of 44k volts. The commutator was made out of aluminum and rotated. It sounds to me he made a pump of constant voltage and provided a booster pump(cap) across a sprinkler type magnetic quenching device. You know the type that has a metal bar hitting the water stream and spraying it all over. I don't think the tank circuit is a tank circuit. It's just a well to hold the pressure for the spark gap to maintain the frequency of the pulses. It's only there to supply a constant pressure and the gap is the frequency controller.
Thats why I said that transistors will never work as the impulse emitter. On the other hand they could be used before the 4 phases of the transformers to originate the ac phases.
znel
Here is a boring yet quite informative video on electrostatic induction.   Take note to how adding the earth ground attracts electrons ( at around 5 minutes ) and apply this to the coils we are using - more specifically what the coils are doing.
http://www.youtube.com/watch?v=pJ36EtABLAk&feature=results_main&playnext=1&list=PL620B5F20A22970A3
Tesla worked with nature, not against it.   If you simply read his words without applying it to real experiments then they are just words.   You can interpret what he's saying in an infinate amount of ways but when you experiment with what he's talking about you will have the " ahh ha " moment of what is meant.
Look closely at tesla's circuits, for the most part in his later works they were all passive oscillators, not driven.   He only applied a charge to start the process and to maintain the charge.   A man made imbalance that allows nature to fill the gaps to balance the system.
Let's examine a simple transformer for a moment... you have a primary and secondary.  The primary is connected to an oscillator ( typically 50/60hz )   When the secondary is connected in a closed loop on the output side from the coil into say a TV set and returned to the coil.   There is no electron exchange in that system, all the electrons are already in the secondary loop and conductors, we simply excite them to power the TV - giving them a vibration.    In an open system such as one wire or wireless we are doing the same thing with the exception that we are now connected to nature to form the loop.   Everything is filled with electrons in a scalar form, everything is vibrating at it's natural resonance.   That ringing in your ear - the high pitched ring you can hear but you can't - is your personal frequency.   If you briefly overlap someone else's frequency you have a DejaVu moment with similar thoughts....coincidence or real communication at a natural level?
Ok, fellow experimentor's... back to work....
