0 Members and 162 Guests are viewing this topic.
jbignes5
Quote from: Hope on December 21, 2011, 02:36:11 PM
I can not accept that a coil (Rodin) being 62% MORE efficient than ANY coil ever designed can not be of MAJOR benefit to our project.  AND the bifilar coil's properties as well being much needed in the obtaining of the most efficient circuit working toward using the forces of nature (which is what we are TRYING to do).  My design thoughts are this:  Rodin for extracting and or adding constriction of the fields (making diode action in copper and/or aluminum)..Bifilar coil(s) used for all their properties of containmentision.  Coil peak shorting, magnetic focused spark gaps.  Shielding that acts to buck back and keep containment and focus of electrical/magnetic properties.  These alone should be enough to make complete cycles of the expansive forces and the contractive nulls.  It's like this fluid flow has use of what can be thought of as electrical gravity, the nulls being compressible a bit and the excited expansive not compressible (or to a much less extent).
This does not even include the extra loose heat shed from decaying elements thru natural or man made nuclear magnetic resonance.
What are the differences of these magnetic verses static charges and field movements?  I know, I know ...also of what is taught being a electrical engineer...BUT what those relationships have to do with what we are finding and are NOT taught is going to make all the difference.
How do we master life's known forces?   We have learned as children by using our senses to manipulate our surrounding.  Then it would stand to reason that we need to SENSE these other unseen forces in that we might be enabled to master them.  Perhaps our efforts should not be limited to the final achievement of what we call free energy.  But also to first  include the steps of SENSING these forces and thus making them subject to our efforts as we do when working with wind, water, fire...etc.   I want feedback from everyone and this includes you all as to tap the group mind on this subject.  It is not my intention to derail this fine topic but to enable it further with all the expedience it deserves.  For some reason we have skipped this step of making our unseen forces sensible.  If the moderator wishes to place this into a new topic for discussion so be it.  But until we bring these unseen things into the light of sensibility we are groping in the dark.
edited of correctness (if possible) at least cohesiveness.
The problem is that the Rodin coil has a different axis. When a sphere magnet is dropped into the center it rotates with an axis of across the winds. It doesn't spin axially like anyone would think normally. So the fields do not run in the traditional swirling motion. Using it as a focus-er would be more like it or a pickup like a huge fan blade. The field is very complex in the Rodin coil especially when it is given or exposed to impulses. Anything that moves adds to the momentum of the energy through the wires and it accelerates the energy in the process. Given the path of the bifilar winding this acceleration is amplified. It pulls on itself. A very strange effect actually. Same amount of charge just delivered faster. It seems that if you get the resistance down to sub levels it creates a greater amount of force and since the bifilar has only the resistance of the material of that wire it would make sense to lower that resistance down to null amounts by paralleling bifilar coils. This way we could shoot that impulse with very little loss and maximum force.
I am wondering how the bifilar coils all parallel would effect the Tesla's coils external field?
Jimboot
Quote from: itsu on December 21, 2011, 09:28:24 AM
@ Jimboot,
i have problems visualizing what you did.
Could you perhaps make a drawing on where you put these diodes etc
attached is the third coil.
Thanks,  regards Itsu
(http://farm8.staticflickr.com/7142/6550844769_6622dfe583_b.jpg)
frantz
To All whos try replicate Delmorto kacher,
I think Delmorto "forgot" show whole elements of his device.
When you look on the top of HV coil you will see white tape. What is under tape? I think there is metal flat ring (aluminium or copper).
When we analyse Tesla coil we will see ball or torus on the top which is a capacitance od the secondary coil.
Delmoto did the same. put the capacitance on the top but not the same like in the ordinary Tesla Coil. Capacitance in Delmorto device have to covers, one outside of tube (not showed) and second inside (was showed like copper pipe cut along).
As we all know, magnetic coupling with loud destoing whole resonance but electric (field) do not.
At this point we have charged capacitor which we can use (without loss) to connecting to the loud via the third coil or step down transformer.
Somebody on the forum wrote about frequency on which work Delmorto kacher (some harmonic), not exacly because HV coil have self capacitance and additional capacitance on the top of the HV coil.
At this point we can calculate correct frequency at which  can dork our device.
I think Delmorto is a smart man.
What you think?
regards
frantz
frantz
jbignes5
It wrote the message just the server burped and it said it error'd, it didn't actually the server lagged.
Well that brings up a good point what does aluminum foil have to do with this process. Tesla was sure impressed with it. It might be that this energy is transmitted better through aluminum and even reflected better (static induction wise). Too many variables to look at.
