0 Members and 163 Guests are viewing this topic.
znel
Quote from: jbignes5 on December 23, 2011, 05:22:27 PM
Another interesting effect.. to ponder.
http://www.youtube.com/watch?v=UUvQJIwezW0&feature=feedu
Something interesting like the yoke experiment:
  http://www.youtube.com/watch?v=71q1DPsFemw&feature=youtu.be
Not sure I can think of an application for the first one but it is interesting.    The second is simply using the A field of the toroid.   I've done a few dozen experiments with toroids used in this way...
jbignes5
Quote from: znel on December 23, 2011, 06:21:20 PM
It had me going for a bit but this is the trick. Well how do magnets work then inside? If the round toroid was a long cylindrical magnet what is driving it? I don't think there is any magnetic field at all in the magnet. It is a surface effect and not internal. What if it is only a voltage charge holding the magnet in order? The electric field is the originator and any magnetic field would be external or environmental. Once the voltage charge builds then it attracts the magnetic path to it binding it in pathways around the magnet in some fashion. This way the only thing a magnet needs is a big static charge in it. You could think of it as a capacitor of a sorts. Think of the lines of force are actually speeding particles that act like this: http://www.youtube.com/watch?v=M4rT_SkhTy8
Going from one side north to the other side south.. This could be it! You have movement from pure static voltages. These particles are the vehicle of all voltage potentials and they turn for a very good reason. It's the shape of the particle. Static electricity by itself can not do a thing. It has to have a motivator and this particle I have been theorizing about is the perfect conductor of this static potential. It has faces that present it's charge to the environment. It's charge is at the base and to a greater extend internal that is shielded by the body of the particle and I believe it is a 3 sided pyramid.
The charge that goes through the crystal is evident by the electric clicker lighters. When you compress the structure it squeezes some out of the structure and if a path is included it flows back to the other side. When there isn't a path it luminates! This structure I believe is very spongy like but in a rigid sense. Almost mechanical.. When left alone it collects charges to fill it's internal structure. Coincidentally this is the same kind of electric phenomina we see in statics but with order and directional flows!
Also in my researches I saw this video of a guy using a big toroid ring in between two terminals of a high voltage transformer. This creates a shield and the voltage will go around the ring if it does. This proves there is a barrier surface inside of the toroid. I'm not sure if he had coils on the toroid or not. Hmm... But at 300k volts it was impressive that not one lick of streamer went through the ring.
http://www.youtube.com/user/Photonicinduction?feature=watch#p/u/73/2mtrnhwAtgE
He calls it a barrier lol
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
jbignes5
crowclaw
