Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 195 Guests are viewing this topic.
grizli
Quote from: romerouk on June 19, 2010, 01:23:12 PM
Today I have built another identical  with the original one. I have used same wire, same pvc, everything like before.The first attempt showed 2.4 amps for 10x100w bulbs. I have disconnected everything and connected the original one. It shows 1.8 amps... connected back the new coil and the 2.4 amps again.
Two identical coils should behave identical or  at least close enough. The only visible difference is the spacing between the big coil windings as the other spacing for the  long windings are identical.
I have adjusted it and the amp goes higher, 2.8amps. I was not able to adjust the spacing to reduce the amperage down to below 2 amps.At this moment in time I am afraid to even change the smallest thing on the original one thinking that I might not be able to bring it back to this stage. I need to play a bit more with the second coil and see if I can do more adjustments. Many of people here are wondering why J L Naudin and me are reporting low amperage and now I have discovered this big coil spacing. Maybe there are other differences but this is all for now.
I was expecting that some of the replicators will have similar results with me or  J L Naudin and I was wondering myself what is everyone doing wrong? The SG must be also very, very small distance between the rod terminals.
I will do  a video or some pictures next time I will go back to work on it, for now I need some time to relax.
All the best,
RomeroUK
For last results do you use Naudin diode orientation that makes voltage doubler , or just diode in series with cap parallel ?
bolt
Quote from: retrod on June 19, 2010, 10:30:40 AM
Mercury tube spark gap  :o wear UV eye protection!!
http://hidemyass.com/files/o5GxW/
Also available on this boards 'downloads' section.
Hey isn't it nice, smooth and quite with mercury vapor? :) Glad to see you tried my proposal.
BTW 99% of those bulbs are UV shielded but have to be slightly careful with one anomaly. Its called TELEPORTING. If you get any signs of metal taste in your mouth TURN IT OFF!.
wiki "Teleportation is the transfer of matter from one point to another, more or less instantaneously. Teleportation has been widely utilized in works of science fiction."
heheheh:) Little do they know or rather don't want you to know.
Metal halides can do this too under Radiant operation but although they work nice as spark gap they wont do dual function and act as a HT power diode.
Need to do PF mods and ballast next using run caps then you will win this low current contest hands down and get more OU then anyone else:) Dont forget to allow warm up time on these lamps before taking final measurements.
dllabarre
Today I have built another identical coil with the original one. I have used same wire, same pvc, everything like before.The first attempt showed 2.4 amps for 10x100w bulbs. I have disconnected everything and connected the original one. It shows 1.8 amps... connected back the new coil and the 2.4 amps again.
All the best,
RomeroUK
If you have an inductance meter can you take these measurements?
1) disconnect the large 6 turn coil from the other 2 coils (leave the other 2 connected to each other) and disconnect from the rest of the circuit and grounds.
2) measure the inductance of the 2 connected coils together
3) measure the inductance of the 6 turn coil
4) reconnect the 6 turn coil to the other coils and measure the inductance
I'd like to see how your inductances compare to mine.
Thank you,
Don
vrand
Quote from: retrod on June 19, 2010, 04:46:54 PM
I hiked five miles to the bulb outlet today. They had some unmarked lamps that appear to be Mercury vapor, on closeout for $1 US ea. Here is the first test using the new lamp as a spark gap.
http://www.youtube.com/watch?v=zKAG257hoVU
Thanks for sharing   :)
Looks like you ran the mercury lamp in series with that small U shaped plasma tube?
Notice any differences vs the spark gap?
retrod
Quote from: vrand on June 19, 2010, 11:13:44 PM
Yes, when I run three mercury gaps in series a 1 ft x 1 ft square of aluminum foil nearby is greatly attracted to the floor. I wonder what might happen if I place somthing on it? I guess that would be off topic. Thanks for asking though.
