Calculating torque
Started by solinear, June 27, 2009, 03:45:59 PM
solinear
I'm working on a design and while I can calculate the force for a magnet, I don't know how to calculate the torque that is generated.  Can anyone help me with the calculation of torque generated by a 3"x1/8" N42 disc magnet that is 1mm from an iron bar (N42 magnet = 3075 surface gauss)?
Thanks
robbie47
Quote from: solinear on June 27, 2009, 03:45:59 PM
Can be done using FEMM simulation.
There are lots of different types of iron though....
If you let me know the dimensions of the iron I might be able to help you out.
solinear
1/2" diameter, 3" long.  Just going to use a bolt for this.
Low-Q
The torque is also detemined by where in the radius of the wheel you put the magnetic setup. Because torque is usually a force that is measured 1 meter from center of a wheel, you must find the force first, and then use the radius to calculate the force at 1 meter from center, there you have torque. Use FEMM. It works pretty good. Need help with it, just let us know.
Iguess the magnet has a 3rd dimention also, not only 3"x1/8" (We need to know Width x Hight x Depth of the magnet).
Vidar
solinear
Height and width are the same.  Disc magnet (one dimension is a circle, in this case, the 3", which is also the pole).  The 1/8" is the depth.
