Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
electricme
@ freepow,
Quote from: freepow on November 16, 2009, 12:43:24 AM
:'( Sorry to dissapoint everyone and myself, but I got a scope shot of my normal EER ( just Galv-pipe and copper tube in the ground ) photo #1 = frequency waves and dc-volts
my EER in PVC slot in the ground is photo #2 = just straight line dc-volts
Results very disapointed in EER in PVC slot in the ground... no frequency waves !
All these results are scope + to EER +  and  scope aligator clip to EER -
Don't be disapointed, this is why it is called research, you found out something, and you shared your findings, good work.
Now, remove the EBC in the PVC housing, and put it directly in the ground, then measure it again, record it.
Then take it out of the ground and pop it back into the PVC housing again.
See if there is any differences between tests.
Good work freepow ;)
jim
freepow
@ Jim, Will do !
I'll report my findings soon !
freepow
@ all,     I have a question... If these Earth currents or magnetic energy is actually flowing through the Earth, then why did'nt my EER in the PVC housing... (which is in the ground) ... pick up these waves like a normal EER probes buried in the Earth would ????
cetainly the PVC would not stop those waves or frequencys.
If those waves or currents need continueous earth to travel through then is'nt it really a galvanic method ??
because my EER in PVC in the ground should have picked up something but instead it read on the scope just like measuring a normal dc battery with just a straight line...
It appears those waves or frequencys travel through the ground, but cant seem to continue through the PVC tube to penetrate the copper tube, meaning it must have a continueous unbroken line of Earth ???   WHY ???
IotaYodi
QuoteIt appears those waves or frequency's travel through the ground, but cant seem to continue through the PVC tube to penetrate the copper tube, meaning it must have a continueous unbroken line of Earth ???   WHY ???
Very few wavelengths in the electromagnetic spectrum are going to pass through the pvc. The magnetic field can pass through but the wavelength and current is stopped and just flows around the pvc.  You could do a cardboard tube and the same thing would probably happen with the 2mhz or so frequency's.
What I know I know!
Its what I don't know that's a problem!
Pirate88179
Freepow:
The way I see it is like this.  Telluric currents are, after all, electrical in nature so to tap into them you need an electrical connection.  In other words, to me it would be like laying a plug near a wall socket outlet, it is close but you won't get any electricity until you plug into the outlet.
This is just my opinion based upon my own observations from my experiments and I may not be correct.  Your experiment helped expand our knowledge base here and that helps everyone.  Great work.
