Thane Heins BI-TOROID TRANSFORMER
Started by shimondoodkin, July 24, 2009, 11:33:44 PM
teslaalset
Quote from: Sprocket on June 04, 2010, 08:05:34 PM
I have a question - the patent states that flux always takes the path of least reluctance and cites that doubling the area of the secondary core material will result in it being half the reluctance of the primary.  Assuming the same core material throughout, will this simple doubling of the secondary's area result in ALL secondary BEMF flux being routed through it, or just a greater proportion of the overall flux?  If yes, then why bother with 'exotic' core materials!
This certainly seems one of the easiest OU areas to prove/disprove.  The 3000% efficiency of the prototype suggests that any old core material, appropriately sized, should show >1 COP...
In principle this is correct.
This would be a good starting point to investigate the patent and phenomenon.
Bruce_TPU
Quote from: teslaalset on June 05, 2010, 06:34:00 AM
Exactly!  What I am thinking is a toroid of low reluctance with two secondary coils wound opposite one another.  Next, a second toroid, cut in half with both ends touching the metal of toroid with the secondaries, NO air gap.  This half of a toroid would have a higher reluctance.  This half a toroid would have a primary coil wound on it.  I do not see it having to be some huge build, to test the principle.  We are not looking for 3000% increase in energy, just a COP >1 to start would be nice!!
Cheers,
Bruce
teslaalset
Blue one is half a Ferrite toroid, black one is a whole MetGlas toroid.
The original idea came from Paul Lawrence.
He calls it his HUE device.
His blog: http://globalfreeenergy.info/
Below picture represents my own build, under investigation right now.
There is another winding on the other side of the MetGlas core.
Bruce_TPU
Quote from: teslaalset on June 05, 2010, 11:57:49 AM
What is the reluctance of each of your two pieces?
To me this is the Thane Patent!  I see PL's work on this.  I think Thanes route (if true) is much more power out or a greater COP.  But PL's work is very good.  I think I like the Thane patent description of what is going on, better though.  If it is indeed the same effect.
teslaalset
Quote from: Bruce_TPU on June 05, 2010, 12:20:30 PM
Bruce,
I don't know the reluctance values. I do know the max. mhu values.
Mhu and reluctance are inverse related. It's explained in Thanes patent.
The mhumax of the ferrite is 4300
The mhumax of the MetGlas is 1000000.
As can be read in PL his blog, I've referred to Thane Heins before.
According to Paul his HUE is different from Thane with respect to his aimed energy salvage. Paul is pulsing the device while Thane seems to use sinusoidal input.
I've indicated earlier in this thread, it is far more complex to operate this example according to Thanes patent text.
A small hint:
The mhu value can be found by looking at the B-H curves of core materials, as the B relates to H as :
B = mhu * H
The highest mhu values occur only at certain current values
(the steepest vertical areas of the B-H curves, current and H are liniar related)
