Thane Heins BI-TOROID TRANSFORMER
Started by shimondoodkin, July 24, 2009, 11:33:44 PM
wattsup
Can I ask a question without being fried and twisted like a morning bacon.
Although I can not question the numbers, seems to me the numbers are so low on such a high core mass, and given as being indicated that the primary is being powered by a reactive power, what is the proof that it is in fact a core flux that is producing the output and not simple air-to-air field transfer.
I would be curious to learn of on thing. Run the BITT as before but just place a single coil of many turns, with or with a core held on top of the primary at about the same distance as the two secondaries are from the primary so it is not on the core of the BITT but floating above it. Then measure if it picks up any energy. I would be curious to see the result of this.
You see, that primary is not only generating a flux in the core, but an outer magnetic field. The secondaries can pickup both flux via the core and the field from around the exterior. If that exterior field is shifting because of AC, then you may have two inputs into the coils. Putting a coil above the primary at the same distance as the fixed secondaries would show us if this is possible and also maybe provide some additional output without touching the core itself.
SkyWatcher123
Hi folks, I'm seeing something interesting in a circuit built similar to what woopy has shown. Though I used what I had, a 2" diameter iron toroid from computer psu and a 1" diameter ferrite toroid placed inside. The 1" toroid has 15 bifilar turns 22 gauge with bedini oscillator circuit. The 2" toroid has maybe 100 turns 24 gauge, havent counted them, that link the two toroids and maybe 100 turns on opposite side of 2" toroid as shown in red in woopy's pic. Using 2AA's as input and 5 leds as a load attached to first secondary. Now input amps without load are showing 180 milliamps, then when first secondary that links both toroids is placed to power leds, input amps drop to 150 milliamps and leds light up. Now, if I then take the other secondary coil at opposite side of 2" toroid and place this coil in parallel with first secondary, the leds double in brightness and input amps drop to 120 milliamps. Maybe this is the effect thane is pointing out.
peace love light
Tyson
niofox
SkyWatcher123,
I was thinking of trying something like this out, but beyond the winding of the toroids I'm a bit fuzzy
Is there a circuit diagram somewhere for this?
Or if possible, could you make a diagram for this setup?
ramset
NioFox
there is this also,Thanes Mary -Jo !!
And broli's Chassis
Chet
Thanks Grandma
ramset
Thanes Mary-Jo
PS
Thane Do you think this could be built with square stock??
And then Tack welded or full weld?
Or drilled and doweled for even more experimenters.
as well as the ability to use diferent metals and coatings, without a costly production commitment!
would make it easier for a lot more replications /experimenters
Test Data link
http://www.overunity.com/index.php?action=downloads
Thanks Grandma
