Thane Heins BI-TOROID TRANSFORMER
Started by shimondoodkin, July 24, 2009, 11:33:44 PM
Jack Noskills
Fluxes don't mix between cores. What is created in the black core by secondaries stays there and bypass the primary. I tried putting air gap between white and black cores but it had no effect compared to case where cores touched. Normally if you form close loop using iron while coil is energized you will hear and feel the vibration. In this case absolutely no effect occurred. So, in my opinion they don't mix.
Of course you do as you please, I just wanted to inform you about this possibility since you are playing with this.
MarkE
Quote from: Neo-X on May 08, 2014, 02:12:16 AM
Are you talking to MEG? Where can i read about magnetic amplifiers? If i failed in this thane heins replication i will turn my transformer into MEG. I will completely remove the center leg then i will replaced it by a magnet.
No, I am talking about magnetic amplifiers, often referred to as mag-amps.  These are devices that control the flow of power by partially or fully saturating under the influence of a control current and thereby passing a much larger load current once saturated.  Google mag-amp.
Neo-X
Quote from: Jack Noskills on May 08, 2014, 08:58:15 AM
Im sorry but i dont get your point whats important here is the primary must high reluctance while the secondary has low reluctance. If you make an airgap between two core, the flux from the first core wont flow to the second core thus the flux will only flow to the two thinner leg of the first core. So the primary and secondary still has the same reluctance. Increasing the area of the core reduces the reluctance so the two core must close together in order to reduce the reluctance in the secondary.
Neo-X
A much better design is split the two black core in to halves then put the two into the sides of the white core so the flux can flow more easily into the black core.
Neo-X
Quote from: MarkE on May 08, 2014, 09:29:36 AM
Its just a power amplifier like transistor except the input was dc controlling the ac output.
