Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
Yucca
OK, I just tried turns ratio 3:24
Again I got almost nothing when trying to force half wave on the secondary. So I let it float and I presume it went into quarter wave.
I managed to get this nice scope shot of the 2 freqs involved here we can see the primary oscillating at 3.42MHz and the secondary as a lower contributer showing 606kHz.
So for device resonance I guess I need to tune these 2 freqs to be the same using cap changes and tap changes. Looks like I need a much bigger cap on the input stage for starters.
Peterae
The large grey capacitors are lower than 2500v DC because of the type and size of the terminals , i found a 4kv oil filled cap and it had massive ceramic insulation on the terminals, because of this i have just ordered 5 of these
1uf 2500vDC
height 4 5/8 inches
width 2 1/2 inches
thickness 1 1/2 inches
weight 0.5kg
I believe these to be higher voltage rating but maybe lower uf see attached picture.
I think we can do without the exact bertonee transformer for now.
I would like to know where to get the clip strips for the coil construction.
The guy selling the caps is in the uk and has 5 more left with postage it comes to £61.50 for the 5
Peter
Peterae
I have now tracked down a supplier that has 5 of the exact large primary caps in stock, i have requested a quote for 2 of them, they are based in Florida and am not yet sure how much they are.
They are mica caps manufacturer is custom electronics
http://www.customelec.com/index.htm
Peterae
Yucca
Wow it was the cap changing value, i wouldn't have thought it should change much over it's operating temperature must have been getting pretty hot i guess.
