Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
bw
Hi Xenomorphlabs,  thanks much for the input and suggestion.  I have no idea how to calculate the resonance frequency of the entire circuit, I thought the transformer set the frequency and the circuit has to be built to match or resonate at that frequency.  I did try reducing the 6000+ feet to much less by dividing but still no big power.  I tried several short versions.  My neon power supply operates at 38-40 khz so I used 39 khz as frequency to match.  The unit I get readings and visable arc from is the plasma globe Don describes, I assumed the plasma globe worked on much higher frequency.   Can you advise me how to find or calculate the exact frequency including my circuit?
bolt
No need to resonant the NST, the NST high voltage supplies ENERGY to the RF tuned tank. Frequency of excitation into tuned tank is NOT important.
Thus 35Khz already contains wide base band signal and harmonics but not so important its the electron volts that will create resonance into the 1st RF tuned tank at any value you choose. This can be just 4 or 5 or 8 turns of wire with cap in the 1000Pf range will give oscillation in the megs range.
NOW the secondary MUST be magnetically and harmonically matched to this singing primary. Non entropy loss coupling appears in magnetic coupling of RF stages where ratio of winding provide E volts squared gains.  If my primary RF coil is 5 turns at 10kv then i have 2000 volts per turn. If my secondary RF tank is 100 turns then now i have 200,000 VOLTS!!
With referenced to the earth the local RE ambient electrons are now extremely violent but this amount of volts is expensive to handle so transformer back down by using a 3rd RF stage of just 1 turn of thick copper wire where C will be very large to LC = F.
Now 2000 volts range is manageable we can use Micro oven caps and diodes.
At 2000 volts the loading is completely isolated from the primary NST driver.  The 200,000 volt is still in operation and the RE will be screaming to maintain neutrality.  It will provide hundreds of amps trying at 2000 volts on our o/p!
Remember number of turns changes volts required. Any frequency required from RF to grid 50/60Hz just add large cap bank to L so the F is lowered to desired operating frequency.  Splitting EM components only happens at RF and the higher the better.  Once conversion achieved to 50/60 Hz normal entropy losses resume. (deliberate choice so you have to pay for it)
RE = RF in energy transformation!
bolt
"The unit I get readings and visable arc from is the plasma globe Don describes, I assumed the plasma globe worked on much higher frequency.   Can you advise me how to find or calculate the exact frequency including my circuit?"
Plasma globe is an exciter source of energy as Electron volts. The frequency does NOT matter.
If you add a 4 turns collector top hat coil and add a microwave oven cap you have made a tuned circuit and the electron energy from the plasma will provide the excitation. The frequency is now transposed into the LC its that simple.  All you need now is earth one side and pull of the power into FWB and run a load. The current provided is a by product of Radiant Energy electrons returning home and has nothing to do with the source!
Thaelin
Bolt:
   This begs the question of what is the best ratio of uf to uh? As a coil should not be more than 4 times the radius, the same goes for coil cap. For good Q, a low ohm coil to larger cap value should be used.
   Any ideas from you?
thay
bolt
4 turns collector that sits on the plasma globe try using Microwave oven cap to start. You can tune LC by adding variable pot R across the C and tune it for best results.
If you have GDO then look for at least 1 meg.
