Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
forest
I feel that the mystery is hidden in primary circuit. It has to produce "radiant energy" in circumference of secondary coils. Neons are required then to tune it.
Peterae
indeed forest
I have been trying to work out the best way to make my primary HV cap up 200nF 4kv, and just stumbled on 2 Dubilier paper/oil caps which are 0.1uf and 4kv, i have never seen anyone use paper/oil caps for tuning coils before (that maybe my inexperience) anyone know if they would work ok
Cheers,
Peter
forest
Some interesting thoughts to consider you find there :
http://www.energeticforum.com/renewable-energy/5009-discussion-re-physics-behind-negative-energy-systems-radiant-spikes.html
First we must learn how to produce radiant longitudinal waves then what Don is saying maybe the response of Earth ambient background to radiant.
I believe you can feel the success if you find you primary emanates electrostatic like field.
turbo
LOL i have a couple of those oil caps too ( 0.1uf 3000v ) and i am always looking for them because they are the only ones that can handle 3Kv  :)
They work Great.
Better then the yellow poly ones. ( if they are not costum made? i might add)
And i have to say, Peter that setup looks great it really does.
I'm wondering which material those secondary coils are made of...
Also it seemed to me Don used 6mm2 car amplifyer supply wire for his primary,which is standed, and it looks you are using somesort of solid tubing for that is that correct?
It could play a major part in high frequency operation however i could be wrong.
Quote from: forest on November 29, 2009, 07:20:51 AM
I think you are right Forest.
I have felt this electrostatic pressure while feeding 35Kv though somehigh voltage diodes to a metal piece as a long spark.
You willknow when you have it because you can feel it comming straight through well isolated tools when you bring them close   :)
It does not hurt it just feels like tingling.
Marco.
Peterae
Thanks guys.
Well i have just ordered those caps from ebay £12 a pop but something that will hopefully last a lifetime.
My secondary coils are made using tinned copper wire i made 2 sets of coils first was 14swg but i decided this was probably thinker that what Don used so i then dropped down to 16swg, i used grommet strip and epoxy to hold it all together, the grommet strip has grooves cut to push the wire down into place and the glue holds it down permanently.
I am not so sure thats speaker wire that he used for his primary, where did you get this info.
It looked very much like HV cable to me which i used, i bought 18awg multi-stranded 16kv wire for my primary.
I have also ordered a sniffer device that Don used in one of the videos to detect the field area, the one that beeps when close to a properly working device.
Peter
