Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
h2ocommuter
I am sure you sent me this the other day i was thinking about searching for that mail as I sat to my computer. I appreciate it buddie.
Zane
a.king21
Hi, mrclean
The only way to really prove this system is to close the loop. Don Smith says if you use a twelve volt battery powering an inverter, his system can both recharge the 12 volt battery and give you surplus power. All you would have to do is to check the 12 volt battery from time to time with the system off. No blown meters - then you would know.
If the twelve volt battery voltage stays the same or increases...... then - JACKPOT.
minde4000
Quote from: mrclean on July 04, 2011, 09:14:21 PM
Hey check out my most recent work on Don Smith
http://www.youtube.com/watch?v=op8HzKc5yao
MrClean,
First - nice work. Second - sorry buddy but your measuring technique for application is wrong. DMM will NEVER show proper readings when used in cojunction with very high frequency and high current spikes. It will serve to mislead you and others.. Perfect exemple was Naudins kapagen measuring artifacts... while at the end proffesional measuring device was employed all "overunity" dissapeared..
Best of luck
