How to create a monopole magnet!
Started by gravityblock, July 30, 2009, 11:00:33 AM
TechStuf
Methinks Stefan is of old soccer hooligan stock, such is his aversion to common sense moderation of his forum.  Imagine what must populate his living room on any given day....
brian 33 going on 4....go play outside for awhile, get some fresh air.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
gravityblock
Expanding on the theory that you must rotate an electron 720 degrees in order to see it's same face.  This means you must rotate the electron twice in order to see it's same face or same side in our reference frame.
Let's say one side of the electron has the electric field (back face), and the other side of the electron has the magnetic field (front face).  The electric and magnetic fields are 180 degrees to each other in an electron's reference frame, but is 90 degrees to each other in our reference frame.
If we're looking at the magnetic field's face (front face), and we rotate the electron 180 degrees in our frame of reference, then we will see the magnetic field to be 90 degrees to the electric field in our frame of reference.  We're not actually seeing it's front or back face.  We are looking at the electron's side, where it's front and back face meet.  If we rotate the electron another 180 degrees in our frame, then we will see the electron's electric field's face (back side).  We will not see the magnetic field, since the magnetic field is on the opposite side. Rotate the electron another 180 degrees in our frame, then we will see it's other side.  We will see the magnetic and electric fields to be 90 degrees to each other in our reference frame.  Rotate it another 180 degrees in our frame, then we will see it's magnetic field's face or front side.  We will not see the electric field, since the electric field is on the opposite side.  This completes the 720 degrees of rotation in our frame of reference and completes the 360 degrees of rotation in the electron's own frame of reference.
This may be theoretical proof that an electron is a monopole with a static charge in it's own frame of reference.  Could it be that the elementary particles in our frame of reference are actually monopoles with static charges in their own frame of reference.  This suggests that the electrons are in a different space-time than us.  If not, then why does rotating an electron 720 degrees in our frame of reference equals 360 degrees of rotation in the electron's own frame.
In order for us to create a monopole in our frame of reference, we have to not only align the spin of the electrons, but we must also align their faces where they will be rotating in sync.  This will get rid of the return path in our frame.  This will cause a magnet in our frame of reference to behave as if it was actually in the same frame of reference as the electrons themselves. One side of the magnet will be a monopole while the other side of the magnet will have a static charge.  The magnet itself may then exist in a different space-time, and that different space-time would be contained within our space-time.
If the magnet is in a different space-time, then it may attract to another mass or repel from a mass that is in another space-time than itself, depending on if the electrons spins are aligned CW or CCW.  In addition to attracting or repelling another mass that is in a different space-time, it may lead to different time-lines according to its speed of travel, it's own spin, and if it's a repeller or an attractor according to if the electrons have a CW or CCW spin. This is all half baked while trying to stay inline with the currently accepted theories of physics.  Please kick it around a little.  At least entertain the idea.  Time for more drugs.   ;)
Thanks,
GB
Paul-R
Quote from: gravityblock on July 31, 2009, 02:17:26 PM
What about this.  As the metal is cooling, spin the metal on what will be it's magnetic axis through the stationary external magnetic field at a high speed...
This reminds me of the proces to make of electrets
http://rimstar.org/materials/electrets/
... a crucial difference being that the electret mixture is non conductive.
brian334
Dear Gravity,
I am having trouble understanding what space/time is.
Will you make us a drawing of space/time so we can
better understand it?
What color is space/time?
What is the density of space/time?
Yucca
deleted doublepost. I´ll make it to 1000 posts if it´s the last thing i do lol!  ;D
